Re: Version 3.06
Posted: Fri Apr 21, 2017 5:18 pm
when i turn off the camera visibility ,shadow pass seems not the right result.
Community Forums for OTOY Customers
https://render.otoy.com/forum/
I don't believe the Wetmap is vertex-based. If you cache a Realflow sim with wetmaps enabled, it'll bake out the map as a PNG image sequence.aoktar wrote:1) I could not reproduce that on first try but I'll check later.nycjunglist wrote:I've been using 3.06 Test4 in production for about 2-3 weeks now, and it's been pretty solid. I needed the motion blur support for Realflow fluids, so thank you for that, aoktar. Two things:
1) It seems that with the Folders option enabled in the Render Passes settings, if you use a token as a directory name, an extra folder with the token name will be created. Everything seems to save as normal in the proper directory though.
2) Is there support for Realflow wetmaps? If so, how can they be used?
2) I need to check this but its propably a kind of vertexmap. Right?
Thanks, I went back and re-read the post you've linked to. I am still fuzzy on how I tell what area of the image is getting x number of samples or what areas got the least/most. Even at default of 256 though it seems to be working really well, I have been able to up samples overall quite a lot and get a much better image for the same render time. I just need to work out now how to tweak these settings to get the magic combination of better results in less time (as opposed to better results in same render time!).bepeg4d wrote:Hi sbstnc,
here you can read about Adaptive sampling:
viewtopic.php?f=24&t=60014
In short, the "Min. adaptive samples" value defines the samples needed to have an estimation of the noise for each pixel, then the Adaptive sampling can use this estimation and starts to work.
As a rule, the more the noise threshold is high, the more samples are needed for a good noise estimation, so with 0.02, 256 samples are enough, with 0.05 you need 512 samples and so on. Going over 1020 samples are not necessary for the noise estimation.
ciao beppe
It's working but there's a refresh problem for nodes. It should update well the nodes if you select "Auto load materials" option.Kretschi wrote:Hi,
3.06 is stable and smooth on Mac OS 10.12 (with Nvidia GPX 980Ti)
Only insertion of node with alt in the node editor does not work...
Great work!
Thanks, Andreas.
What do you want to know? I'm not master for that. But it looks simple if you read notes about that from standalone topic.JavierVerdugo wrote:Hi Aoktar,
the version is very stable, non crash at the moment.
Would you mind to upload a triplanar node scene?
Thank you
It's a renderer issue. I'll ask for that.zxctnt wrote:when i turn off the camera visibility ,shadow pass seems not the right result.
