Page 5 of 14
Re: Version 3.05.1 (23.12.2016) - Latest stable
Posted: Fri Jan 06, 2017 8:16 am
by pxlntwrk
im experiencing almost same behaviour exporting to ORC with scenes contening HDRI.the lighting env seems rotated in ORC (no problem in standalone)
Check viewtopic.php?f=100&t=58328
Posted: Fri Jan 06, 2017 12:40 pm
by aoktar
pxlntwrk wrote:Hi,
It happens only when you have rotation in env. texture as i can understand. Work around is negative value on rotation value until fix come.
Posted: Fri Jan 06, 2017 1:01 pm
by pxlntwrk
aoktar wrote:
pxlntwrk wrote:Hi,
thanks for info :)
Posted: Sat Jan 07, 2017 8:00 am
by David_S
the camera angle changes a lot, when I enable motion blur. Img 1: unchecked, img 2: checked. I found out, that it seems to be related with the motion camera tag, but didn't found a solution.
Also, if you change scatter object display from line to object, scattered object seem to be displaced (img 3 & 4).
OSX 10.12.2
GTX 980 4095 MB
CUDA Driver Version: 8.0.57
Web Driver 367.15.10.25f01
C4D R17.055
OctaneRender 3.05.1
Plugin Version 3.05.1
Posted: Sun Jan 08, 2017 2:25 pm
by thanulee
aoktar wrote:
thanulee wrote:Some scenes when i use the post process tools, update the render. It might be when coherent ratio is more than 0.0. Check it out.
I think that you say update with every click on some scenes. It's known problem and mostly due C4D's update mechanism on cloners+some effectors or so...
Well that might happen as well, but i didnt say that. It updates when i change my bloom and glare for example.
I noticed that if i have my camera/perspective viewport and live viewer same time this bug happens.
If i switch to another tab (i have next to my perspective my render settings for instance) it doesnt happen.
In general wacom is being a bit weird sometimes with c4d and i noticed that with octane as well. I hover something or my pointer passes over the viewport and octane updates.
Posted: Sun Jan 08, 2017 5:43 pm
by aoktar
David_S wrote:Hi,
It seems like a overlook on some parameters in motion tag. It will be fixed on next release. Your other words dont make any sense on me. There's not any functionality to modify the vertexes of distribution objects.
Posted: Tue Jan 10, 2017 10:41 am
by zoppo
aoktar wrote:It seems like a overlook on some parameters in motion tag. It will be fixed on next release. Your other words dont make any sense on me. There's not any functionality to modify the vertexes of distribution objects.
Motion Blur on moving objects with a fixed camera works for me without a problem. I just used it yesterday.
About the scatter: You can see that the distribution of the objects is different in the two previews.
Thanulee, maybe you could render the tree with lines or without smoothing, so we can see which distribution is the one rendered?
Re: Version 3.05.3 (13.01.2017) - Latest stable
Posted: Mon Jan 16, 2017 11:36 am
by max383
Hey ! Nothing important but on Cinema4D R18.039 everytime I close the program I got a message about an Octane plugin crash. But that's just when I'm closing C4D, and the scene is not saved in the bugreports.
Posted: Fri Jan 20, 2017 4:59 pm
by Oleg
Did I missed something or there is no option for saving passes into separate folder for png files?
Posted: Mon Jan 23, 2017 8:20 am
by NVN
max383 wrote:Hey ! Nothing important but on Cinema4D R18.039 everytime I close the program I got a message about an Octane plugin crash. But that's just when I'm closing C4D, and the scene is not saved in the bugreports.
+1
the same goes for me
