Page 5 of 46
Re: OctaneRender for DAZ Studio 3.03.3 [TEST]
Posted: Fri Aug 12, 2016 7:10 am
by face_off
Sadly i'm having a issue after installation, it seems te plugin can not be activated/load
Plugin failed to load!
Filename :
E:/3D Content/DAZ 3D/DAZStudio4/plugins/OctaneRender/plordazs.dll
Name :
plordazs
Author :
Unknown
Version :
0.0.0.0
Reason :
Library could not be loaded. File is not a valid DAZ Studio plug-in, or was made for a different version of DAZ Studio.
Reverting to the previous version works and it loads again. Any advice or could this be an issue with the installation package?
(i'm using the Daz version 4.9.2.70 )
My apologies - there is an issue with the installer. I will post a fix shortly.
Posted: Fri Aug 12, 2016 11:19 am
by face_off
I have fixed the installer and re-instated the download link to release 3.3.3.24 at the top of this thread - so the "Plugin failed to load!" error should now be fixed.
Posted: Sat Aug 20, 2016 1:19 pm
by FastKatt
After enabling Beauty Passes and clicking on a beauty pass to view, sometimes the button to return to the Main Beauty Pass becomes disabled. The only way I've found to fix is to close DAZ Studio and reopen.
Posted: Sat Aug 20, 2016 3:07 pm
by AlfaseeD
Well, I still get the 999 error even after I completely followed your guide.
I'm sure It's not my hardware fault, I never had so many problems with octane in the past.
Anyway I tried a step by step solution on a scene that always crashes.
I started with removing some of the clothes (glossy material with diff, spec, rough, displ maps) and I didn't have any problem until I placed a pair of gloves into the scene that were unable to load some textures. Anyway, before hitting the render button I assigned a simple diffuse material to the gloves with no textures, saved the scene and after 150 samples Octane crashed.
I reloaded the scene after a complete restart, gloves are white with no textures, the render didn't crash at all.
I'm really, really sure the problem lies somewhere that is not my hardware.
Posted: Mon Aug 22, 2016 10:27 am
by face_off
This is a general Octane issue rather than a plugin issue - so I am out of my field of expertise here. However if you get a Cuda 999 error part of the way through a render, it points to either insufficient power from the power supply, overheating, or a hardware error. In general, I think an insufficient power supply would give you a BSOD, and overheating is Cuda error 715, so this really seems to be a graphics card error. Have you tried underclocking your card? What about if you export to ORBX and render in Standalone - does that error too? Are there any displacement maps in the scene which could be causing an issue?
I could reproduce this error - I will see if I can fix it.
Posted: Mon Aug 22, 2016 12:28 pm
by AlfaseeD
Hi Paul,
I know this is an octane general issue but it's really, really frustrating for me.
Yes, I underclocked all the cards and no results at all.
I have a 1200 supply (EVGA SuperNOVA 1200 P2) and its really enough for my system.
Also, since I play a lot of games, I never had any problem with any of them. Sometimes I can play games at max setting and leave octane render an image in background.
In all my renders there are displacement maps, but the most important note is that I tried to switch to the older version of octane and no more errors for me (3.1.1.23).
Posted: Tue Aug 23, 2016 2:00 am
by face_off
Did you try Nvidia driver 358.50?
If you export a problem DAZStudio scene to ORBX and open in Octane Standalone 3.03.3, does it throw an error 999? (You will need to check the Octane Log, since Octane Standalone will not immediately alert you of a Cuda error).
Posted: Tue Aug 23, 2016 2:12 am
by face_off
A suggestion from Otoy - turn on Kernel->Static Noise - does the Cuda 999 error always happen at the same number of samples for a given scene? If so, export to Standalone and confirm that it happens there too, and if so, send the ORBX file to Otoy.
Posted: Tue Aug 23, 2016 2:28 am
by face_off
This is fixed in the next release of the plugin. In the meantime, turning off all render passes with take you back to viewing the main beauty pass.
Posted: Tue Aug 23, 2016 11:24 am
by FastKatt
face_off wrote:After enabling Beauty Passes and clicking on a beauty pass to view, sometimes the button to return to the Main Beauty Pass becomes disabled. The only way I've found to fix is to close DAZ Studio and reopen.
Thanks, Paul. I did find the workaround you mentioned. Unfortunately, it restarts the render, but it is more convenient than restarting the application. Looking forward to the next release!
