Page 5 of 13
Re: Grimm's take on the turntable anim script
Posted: Thu Jan 02, 2014 11:55 pm
by stratified
The advantage of using Octane via Blender is that you way more flexibility while to Lua scripts are just tailored for a single animation type. They are nowhere near as flexible as using Blender. My guess is that at some point we'll have some pretty advanced scripts (for example, Jason is improving his script in every iteration) but I would be surprised if someone would come up with the same flexibility as you would expect from host apps. It's possible but it would require a huge amount of work...
cheers,
Thomas
Posted: Fri Jan 03, 2014 12:49 am
by r-username
stratified wrote:They are nowhere near as flexible as using Blender.
I agree 100%.
Just to clarify it's the most common animation types that I think there should be lua scripts for.
In fact with all the great additions to the turntable script, pan/truck (cam left right) is the only script really needed now.
Thanks again for the great software
cheers, s
Posted: Fri Jan 03, 2014 1:32 am
by stratified
r-username wrote:stratified wrote:They are nowhere near as flexible as using Blender.
I agree 100%.
cheers, s
Well, I hope this isn't the only script that's needed for now. For example, I'd like to see a tool to edit scatter nodes. Right now it's so cumbersome in Octane that there's even a third-party app called "Phantom Scatter" just to do this. I think something like that would be a great script as well and it might make the author a nice buck.
cheers,
Thomas
Posted: Fri Jan 03, 2014 1:46 am
by stratified
pixelrush wrote:I tried a wee experiment in Solidworks. The path here is a projected one arising from an ellipse and a parabola. I then divided the path equally into 24 (edit actually I see one is accidentally repeated) and used a macro to save out the co-ords to a txt file.
This was quite quick and easy to do. Virtually any imaginable geometry could be used as a basis for obtaining the camera position for each frame. All it needs is to be read into the script.
You are right though, how much functionality is enough considering cg apps do this natively?
Still at least if someone wanted to, they could do this type of thing, although you are 'not supposed to'. Just don't tell Uncle Roeland about it
reading in the values generated by Solidworks is trivial, it's actually building a usable user interface that works with generic curves that's the hard problem.
But I think it's still pretty cool that users can draw a path in an app and then use this in Octane.
cheers,
Thomas
Posted: Fri Jan 03, 2014 3:38 am
by pixelrush
Well it may be trivial for some of us, a lot of research effort for normal people
..and Uncle Roeland doesn't want alien generic curve stuff littering his program.
I was thinking of making some generic paths/point lists though for the 'library' with '1.0' as the basis if reading was implemented ie xyz readily scalable in the script. std ellipse 0.5x1.0 -> 7.5mx15.0m with slider.
The thing is too not every app that might ulitise Octane for rendering is a cg one. If you come from Inventor, AutoCAD, SolidWorks or SolidEdge ie engineering programs, they don't have this capability.
Also cg programs don't tend to generate geometrically precise paths like an ellipse, parabola, lissajous figure...
Here attached is a messy sketch as I was thinking about how to do the bits r-username wanted.
Points for endeavour, right?
I think getting the info and doing the linear calcs ought to be easy enough.
I wont start this myself though because someone like Grimm will finish it before I do a couple of lines
Posted: Fri Jan 03, 2014 9:32 am
by pixelrush
BTW unless I am mistaken there is a problem stopping the preview and animation in v0.7.
The [Stop Render] button is greyed out.
Posted: Fri Jan 03, 2014 11:09 pm
by grimm
stratified wrote:Hi Jason,
It isn't mandatory to select the render target before running the script. I used that approach because it was used in the turntable animation in older Octane versions. You could use the combo box exclusively. It's less usefull (I think) if the user has 10 render targets, all named "Render Target". You could give some visual clues by selecting the render target in the editor but I don't think it's worth it. That's just my opinion of course and it's your code. You already made it way more useful than the script we presented initially.
BTW: You don't have to credit Roeland and me in the header of your script. The code we provide can just be used. Of course we don't guarantee that it won't stop the universe.
cheers,
Thomas
Thanks Thomas, although I don't want the universe to end, I wouldn't feel right if I didn't credit you and Roeland. It would be too much like stealing for me to do that.
You make a very good point on the 10 render targets, all with the same name. I put this code together and tested it on 1.24, but it's running very strangely in that for the most part it works except when I don't have a node selected or I select a camera group.
-- Returns all the items, even those owned by nested graphs.
local function getAllItems(graph)
local all = {}
for i, item in ipairs(graph:getOwnedItems()) do
-- for graphs we recursively collect all the items
if item:getProperties().isGraph then
local nested = getAllItems(item)
-- merge the tables
for j, nestedItem in ipairs(nested) do
table.insert(all, nestedItem)
end
else
table.insert(all, item)
end
end
return all
end
-- Returns copies of the original scene graph, the camera node and the rendertarget.
-- This prevents us from modifying the original scene.
function getSceneCopy()
-- get the selected render target
local selectedRt = octane.project.getSelection()[1]
-- find the index of the selected render target node
local idx = -1
local allNodes
local selectedTarg
-- no node has been selected
if selectedRt == nil then
print "no node"
allNodes = getAllItems(octane.nodegraph.getRootGraph())
-- find first render target in root graph
for i, item in ipairs(allNodes) do
if item:getProperties().type == octane.NT_RENDERTARGET then
idx = i
selectedTarg = item:getProperties().name
break
end
end
-- graph/linker node is selected
elseif selectedRt:getProperties().isGraph then
print "graph node"
local nodes = getAllItems(selectedRt)
local rtNode
-- find first render target in selected graph
for i, item in ipairs(nodes) do
rtNode = item
break
end
end
-- now find the render target in the root graph
if item == rtNode then
idx = i
break
end
end
-- render target node has been selected
elseif selectedRt:getProperties().type == octane.NT_RENDERTARGET then
print "render target node"
-- find the render target in the root graph
if item == selectedRt then
idx = i
break
end
end
-- some other node has been selected so error out
else
showError("TurntableG Error!", "You have selected a node that can't be used, please select a render target node or a group with a render target in it.", true)
end
-- see if we could find the node
if idx == -1 then showError("TurntableG Error!","Could not select a render target node!", true) end
-- create a full copy of the project so that we don't modify the original project
local copyScene = octane.nodegraph.createRootGraph("Project Copy")
copyScene:copyFrom(octane.nodegraph.getRootGraph():getOwnedItems())
local copies = getAllItems(copyScene)
copyRt = copies[idx]
local copyCam = copyRt:getInputNode(octane.P_CAMERA)
-- Find all render targets
local renderTargets = octane.nodegraph.getRootGraph():findNodes(octane.NT_RENDERTARGET)
local renTargList = {}
for i, item in ipairs(renderTargets) do
-- renTargList[item:getProperties().name] = item
renTargList[#renTargList + 1] = item:getProperties().name
end
return copyScene, copyRt, copyCam, renTargList, selectedTarg
end
Did some more testing on this, even when you select a render target node, I'm getting random nodes returned from the getSceneCopy() function. Sometimes it is lucky and it gets the correct node. Most of the time it gets some other random node. Very strange?
Jason
Posted: Fri Jan 03, 2014 11:14 pm
by grimm
pixelrush wrote:BTW unless I am mistaken there is a problem stopping the preview and animation in v0.7.
I just tried it with Octane 1.24 and it worked. Maybe I fixed something since then. V0.8 is almost ready, try that and see if it works.
Jason
Note: now that I think about it, you might try re-downloading the zip file and see if it fixes the problem.
Posted: Sat Jan 04, 2014 2:55 am
by pixelrush
Re-downloaded and its working correctly.
Not sure what caused that
anyway its ok.
Looking forward to v0.8
Really appreciate you doing this/sharing with us.
A steep learning experience for me I am afraid
Posted: Sat Jan 04, 2014 4:42 am
by stratified
grimm wrote:stratified wrote:Hi Jason,
cheers,
Thomas
local all = {}
-- merge the tables
end
else
end
end
return all
end
local idx = -1
local allNodes
local selectedTarg
print "no node"
idx = i
break
end
end
print "graph node"
local rtNode
rtNode = item
break
end
end
idx = i
break
end
end
idx = i
break
end
end
else
end
end
end
Jason
Hi Jason,
I think the issue is that you're trying to index
copies with the index found by scanning
allNodes. You're implicitly relying on the fact that the order of these tables is the same. I tested it and sometimes it is, sometimes it's not. That's why you get these strange errors.
It all boils down to finding the copy of the selected render target and this is a bit tricky. I'll think about it some more, maybe we can simplify it somehow.
cheers,
Thomas
