Page 5 of 13
Re: Octane exporter for C4D version 0.12b (current)
Posted: Wed Nov 28, 2012 12:38 pm
by macray
Hi guys,
does the plugin also work with the 1.0 release? and if so - why do they advertise some special versions? Are these ones integrated directly in the program and have no more standalone gui? (that would be even better than having to export all the time...)
Posted: Wed Nov 28, 2012 9:44 pm
by JackMcRip
GREAT
I love Octane in Version 1.0 !
The last month I less use Octane.
It feel much faster and smoother !!!
The Export for Cinema 4D ist great, too!
But I missed Lights when I export.
Why this limitation must be?
EDIT: If I export materials, the color export. And Reflection (Mirror) is export,too.
But If I export transparenz, the color of the material is not exported and the transparenz is ignored.
The Color of lumination wasn't export, too
This could be export to the emitter !?!
Posted: Wed Nov 28, 2012 10:20 pm
by abstrax
macray wrote:Hi guys,
Yes, of course will the export plugin work with version 1.0. Nothing has really changed in the way exporters need to work. The image you have seen in the 1.0 release post is a screenshot of a new plugin in development (not by me) that will integrate Octane into C4D.
Cheers,
Marcus
Posted: Wed Nov 28, 2012 10:30 pm
by abstrax
JackMcRip wrote:GREAT
The material export via OBJ/MTL files is very limited, which is why you have to set up the materials in Octane. The materials exported during the initial export are just there to give you something to start with.
Cheers,
Marcus
Posted: Wed Nov 28, 2012 11:43 pm
by JackMcRip
abstrax wrote:JackMcRip wrote:GREAT
Cheers,
Marcus
Maybe you can get the way with an extra "c4d-octane"-File. There ist written in some more infos about hte materials.
The Name of the materials are right.
In the file you can write the name, and the settings.
In Octane the file is loading and starting a script, that import informations from the extension file.
Or if Octane don't support a script language, maybe this:
After C4D-Plugin save the extension file with the added information of the material. In Octane import the scene. Octane save the scene. An application start to change the octane file and fill in the material infos from extension C4D-Plugin writing file.
Posted: Wed Nov 28, 2012 11:53 pm
by abstrax
JackMcRip wrote:Maybe you can get the way with an extra "c4d-octane"-File. There ist written in some more infos about hte materials.
Please read the Octane manual to understand how the export workflow works. In a nutshell: The exporter exports the scene as OBJ/MTL file combo. The materials in the MTL file are very limited and are meant to give the user a starting point. The user then sets up the materials in Octane (the material system in Octane works very different to the material system in C4D) and saves the scene and closes Octane. If you change the geometry in your C4D file and export again, Octane re-links the materials from the Octane scene file with the new geometry.
Again, please read the manual and try that workflow.
Cheers,
Marcus
Posted: Thu Nov 29, 2012 12:01 am
by JackMcRip
Yes of course
But maybe there is a way the get the material export more feeling like in C4D.
Colors, reflection strength, opacity, ect.
I am looking in the Octane file and search at the Material-Name. Here ist "mat".
I found and see that:
<NodePin>
<typename>Mat</typename>
<id>1</id>
<pintype>20005</pintype>
<hasinternalnodegraph>true</hasinternalnodegraph>
<basenodeid>1</basenodeid>
<basenodepinid>0</basenodepinid>
<internalnodegraph>
<NodeGraph>
<name>Mat</name>
<currentnewnodeid>2</currentnewnodeid>
<currentnewnodepinconnectionid>1</currentnewnodepinconnectionid>
<nodes>
<Node>
<name>Mat</name>
<typename>glossy</typename>
<id>1</id>
<position>0 0</position>
<inputnodepins>
<NodePin>
<typename>diffuse</typename>
<id>0</id>
<pintype>20000</pintype>
<internalnodegraph>
<NodeGraph>
<name>diffuse</name>
<nodes>
<Node>
<typename>RGBspectrum</typename>
<id>1</id>
<parameters>
<rgbvalue>0.612066 0.612066 0.612066</rgbvalue>
</parameters>
<inputnodepins>
</inputnodepins>
</Node>
</nodes>
<nodepinconnections>
</nodepinconnections>
</NodeGraph>
</internalnodegraph>
</NodePin>
<NodePin>
<typename>specular</typename>
<id>1</id>
<internalnodegraph>
<NodeGraph>
<name>specular</name>
<nodes>
<Node>
<typename>floattexture</typename>
<id>1</id>
<parameters>
<value>1</value>
<minvalue>0</minvalue>
<maxvalue>1</maxvalue>
<usetexturealphaui>false</usetexturealphaui>
<isloglincapable>false</isloglincapable>
<uselogscale>false</uselogscale>
<resolution>0.001</resolution>
<modified>true</modified>
</parameters>
<inputnodepins>
</inputnodepins>
</Node>
</nodes>
</NodeGraph>
</NodePin>
<NodePin>
<typename>roughness</typename>
<id>2</id>
<internalnodegraph>
<NodeGraph>
<name>roughness</name>
<nodes>
<Node>
<id>1</id>
<parameters>
<value>1e-005</value>
<minvalue>1e-007</minvalue>
<isloglincapable>true</isloglincapable>
<uselogscale>true</uselogscale>
<resolution>1e-007</resolution>
</parameters>
<inputnodepins>
</inputnodepins>
</Node>
</nodes>
</NodeGraph>
</NodePin>
<NodePin>
<typename>filmwidth</typename>
<id>3</id>
<internalnodegraph>
<NodeGraph>
<name>filmwidth</name>
<nodes>
<Node>
<id>1</id>
<parameters>
<value>0</value>
</parameters>
<inputnodepins>
</inputnodepins>
</Node>
</nodes>
</NodeGraph>
</NodePin>
<NodePin>
<typename>filmindex</typename>
<id>4</id>
<pintype>20001</pintype>
<internalnodegraph>
<NodeGraph>
<name>filmindex</name>
<nodes>
<Node>
<typename>float</typename>
<id>1</id>
<parameters>
<value>1.45</value>
<minvalue>1</minvalue>
<maxvalue>8</maxvalue>
<usetextureui>false</usetextureui>
</parameters>
<inputnodepins>
</inputnodepins>
</Node>
</nodes>
</NodeGraph>
</NodePin>
<NodePin>
<typename>bump</typename>
<id>5</id>
<internalnodegraph>
<NodeGraph>
<name>bump</name>
<nodes>
<Node>
<name>bump</name>
<id>1</id>
<parameters>
<value>0</value>
</parameters>
<inputnodepins>
</inputnodepins>
</Node>
</nodes>
</NodeGraph>
</NodePin>
<NodePin>
<typename>normal</typename>
<id>6</id>
<internalnodegraph>
<NodeGraph>
<name>normal</name>
<nodes>
<Node>
<name>normal</name>
<id>1</id>
<parameters>
<value>0</value>
</parameters>
<inputnodepins>
</inputnodepins>
</Node>
</nodes>
</NodeGraph>
</NodePin>
<NodePin>
<typename>opacity</typename>
<id>7</id>
<internalnodegraph>
<NodeGraph>
<name>opacity</name>
<nodes>
<Node>
<id>1</id>
<parameters>
<value>1</value>
<usetexturealphaui>true</usetexturealphaui>
</parameters>
<inputnodepins>
</inputnodepins>
</Node>
</nodes>
</NodeGraph>
</NodePin>
<NodePin>
<typename>smooth</typename>
<id>8</id>
<pintype>20003</pintype>
<internalnodegraph>
<NodeGraph>
<name>smooth</name>
<nodes>
<Node>
<name>smooth</name>
<typename>bool</typename>
<id>1</id>
<parameters>
<value>true</value>
</parameters>
<inputnodepins>
</inputnodepins>
</Node>
</nodes>
</NodeGraph>
</NodePin>
<NodePin>
<typename>index</typename>
<id>9</id>
<internalnodegraph>
<NodeGraph>
<name>index</name>
<nodes>
<Node>
<name>index</name>
<id>1</id>
<parameters>
<value>0</value>
</parameters>
<inputnodepins>
</inputnodepins>
</Node>
</nodes>
</NodeGraph>
</NodePin>
</inputnodepins>
</Node>
</nodes>
</NodeGraph>
</NodePin>
<NodePin>
It is looking like it is possible to change the material settings after import in octane, and save with octane.
Maybe, with the C4D-Plugin!?
Please don't be angry at me.
I try to help
Posted: Thu Nov 29, 2012 12:35 am
by abstrax
JackMcRip wrote:Yes of course
I try to help
The OCS file format is not open and is subject to changes, which is why exporters should neither write nor modify OCS files. Of course, you can do whatever you want in your own plugins, but I won't change the exporter, because it's pretty much guaranteed to break in the future.
Maybe keep an eye on this site, because there is currently an integration plugin for C4D in the making, which (hopefully) will allow you to do what you want.
Cheers,
Marcus
Posted: Thu Nov 29, 2012 8:31 am
by JackMcRip
sounds nice
Thanks for your time and work!
Posted: Fri Nov 30, 2012 9:53 am
by indexofrefraction
Marcus
to render from within c4d (like the max plug) ?
that would be great !!!!
any rough release date for that?
