Re: Version 2.24.2-TEST5.2 (02.12.2015) - Test only
Posted: Thu Dec 03, 2015 1:14 pm
carterner wrote:When i chose the "use csv file",C4d system crash
same here on win7 R17.032
Community Forums for OTOY Customers
https://render.otoy.com/forum/
Use dylib, etc.. missing files from previous build(test 5.1 or test4). All base files are same for 2.24.2 releases. I'll fix files.David_S wrote:Hi there,
Im on OS X 10.11.1, latest web driver and Cuda 7.5.21.
2.24.2-TEST5.1 was fine, but 5.2 doesn't appear in the plugin menu. Tested with R17 and R16.
I understand all and I agree with you that now is better that you stay focused on v3.0, I hope this feature will be included in this new relese.aoktar wrote:You'll not believe perhaps, but it's very hard. Completely will broke all internal structure of plugin and will cause lot of extra issues for me. So i'm not preferring to try this. I'm spending my time for 3.0 and stabilisation of 2.24. I hope you understand that.augdalmo wrote:Hi Aoktar
congratulations for the latest release, SOLO mode implemented on LV is very useful, and if I "edit on Standalone" the SOLO oject/s will be exported, it will be fantastic if we can export also ONLY the materials of exported objects! For very large scenes with a few clicks we can isolate object/s and related materials, this would save a lot of time. I hope you will consider a short-term goal.
I thank you for all the improvements that you give us day after day.
Martinmartincarlson wrote:Hello!
Might have missed earlier comments on this - but still:
In this version - if I create a material in the regular C4D-way and then open the node editor - nothing is connected? It used to be in earlier versions. Bug or some setting?
is there a place still to download test5.1 or test4? don't have my old copy and can't find a link.aoktar wrote:Use dylib, etc.. missing files from previous build(test 5.1 or test4). All base files are same for 2.24.2 releases. I'll fix files.David_S wrote:Hi there,
test5.2 files are fixed.tmcalvin wrote: is there a place still to download test5.1 or test4? don't have my old copy and can't find a link.
It's fixed. How do you produce it? It's fine on my usages. A video would be great to show it.milanm wrote:Martinmartincarlson wrote:Hello!
I reported this earlier and it's not fixed yet. It's there since 2.24.2. Works fine in the 'latest stable'.
You can try to stop live view, open node editor and resend again. Also if material editor window is open nodes will be connected..
Those are just workarounds.. It's definitely a bug
Milan
