Page 4 of 4
Re: Cinema4D version 2025.2 - v1.5
Posted: Wed May 21, 2025 8:35 am
by bepeg4d
UON.Visuals wrote: Wed May 21, 2025 6:56 am
This version is causing 2 of my render nodes to fail continously, no matter what project I load.
All nodes have the same Nvidia drivers:
it is an Octane core issue, and I have the same issue only on my Render-Node machine with Win 10 and RTX 2070 Super, but we have not found the culprit yet
What are the specs of yours Render-Nodes?
Surely it is not an Nvidia driver issue since I have tried several ones without success, and this is only happening with Network rendering enabled, the machine is rendering without issues if net render is disabled.
ciao,
Beppe
Posted: Wed May 21, 2025 10:24 am
by Turck
First of all thank you to the team.
Drag & drop an environment HDR from the asset browser seems not work. It does work from the windows explorer though.
Posted: Wed May 21, 2025 7:23 pm
by mojave
Could you please share more information about your specific setup? HW, drivers, OS version would be helpful. Thank you.
Posted: Thu May 22, 2025 3:44 am
by UON.Visuals
All systems are on Windows 10 pro with latest windows updates
Crashing machines:
Working machines:
One difference between my working machines that crash and the ones that don't: The ones that crash need to have Windows activated
Posted: Thu May 22, 2025 7:32 am
by bepeg4d
Thanks for your collaboration!
Please, try to run Standalone 2025.2 on Render-Node with RTX 2080 Ti and RTX 3080.
Then go to menu File/Preferences/Devices, and disable RTX 2080 Ti, in order to render only with RTX 3080,.
Then open any .orbx scene and start rendering.
Then go again to Preferences/Network Render, connect the working Render-Node machine, and close the panel.
In my case, with 2x RTX 2070 Super, net render starts for few seconds, then there is a blue circle on the mouse arrow, and Standalone quits unexpectedly without errors.
ciao,
Beppe
Posted: Fri May 23, 2025 12:25 am
by desire
Hello!
Often get strange results with MoBlur on cloner object. There are some frames appear with weird smudged clones over image sequence.
Tell me please, what I miss this time?
previously, more or less successfully solved those effect by choosing "transform/vector" in the motion blur bookmark of octane object tag
thank you
Posted: Fri May 23, 2025 8:32 am
by bepeg4d
what happens if you change the MoGraph Cloner mode to Render-Instance?
If there is no deformed geometry, you should keep the motion blur to Transform only.
ciao,
Beppe
Posted: Fri May 23, 2025 3:02 pm
by desire
bepeg4d wrote: Fri May 23, 2025 8:32 am
ciao,
Beppe
Yep in final worked changing clone mode to Render-Instance or Multi-Instance modes.
If change Instance to Render-Instance without resending a scene, clones dissapear... So I miss resending a scene.
Thank you for your answer.
Posted: Wed May 28, 2025 7:41 am
by bepeg4d
@UON.Visuals:
Net Render issue with RTX 20X0 and Win 10 in 2025.2/2025.2.1 has been internally fixed, and will be part of next Standalone update.
ciao,
Beppe
