Page 4 of 8
Re: Cinema 4D version 4.04-R2 (Latest stable) 06.05.2019
Posted: Wed May 15, 2019 3:09 pm
by lucioing
Hi Ahmet!
I'm still working with V4.01.1-R2.
My CUDA driver is:
CUDA Driver Version: 387.178 under MacOS 10.12.6
So, can I update to latest release? 4.04-R2
Thank you
L.
PS I'm working with a Hackintosh... :roll: So, as you know, isn't easy to update o.s. ...
Posted: Wed May 15, 2019 3:14 pm
by bepeg4d
Hi Lucio,
please upgrade to v4.04-R2.
At least you need to update your RXX c4d copy to the latest build.
No problem with CUDA 387.178 under Sierra.
ciao Beppe
Posted: Wed May 15, 2019 6:51 pm
by lucioing
Thank you Beppe...
L.
PS Fatte senti'... :lol:
Posted: Fri May 17, 2019 9:34 am
by selor
Link for Offline MANUAL didnt work ::!!: :mrgreen:
Posted: Fri May 17, 2019 3:51 pm
by lucioing
OK. I'm in trouble !
4.04 on main works fine
4.04 sa on slave works fine
daemon on slave doesn't works.
Here's some screenshot.
What's wrong with slave?
L.
Posted: Fri May 17, 2019 3:56 pm
by bepeg4d
With High Sierra you need CUDA 410.130:
https://www.nvidia.com/object/macosx-cu ... river.html
Just install on top of the current installed version.
ciao Beppe
Posted: Fri May 17, 2019 4:14 pm
by lucioing
Thank you Beppe... I'll try later...
L.
Posted: Sun May 19, 2019 4:33 pm
by 3dworks
beppe, just curious, what is wrong with 418.163? cheers markus
Posted: Mon May 20, 2019 3:44 pm
by bepeg4d
Hi 3dworks,
the question should be asked to Nvidia.
No 418.xx CUDA driver versions are working with OctaneRender, and as far as I remember, it was never happened in the past.
Nvidia has fixed the issue in 419.xx and higher, but never published a fixed version for Mac, at least until yet.
ciao Beppe
Cinema 4D version 4.04-R2 / live viewer issue when loading scene
Posted: Fri May 24, 2019 1:11 pm
by 3dworks
i am having an issue with live viewer and i can reproduce this in all my complex scenes.
when a scene is loaded in C4D and i start the live viewer the first time, data will be transferrend very fast to the engine, only a few non-octane materials in the scene are converted. if i stop and restart that preview render (also after i closed and reopened the lve viewer window), and start a preview, octane will take a much longer time to send all the data to the engine. i also can see that status will report a material conversion for ALL the used materials in the scene. in many cases it goes from a few sconds to nearly a minute! is this a known bug or could it be some setting which causes this?
C4D prime R20 V20.059 mac / macpro 5,1 48G RAM, nvidia 980ti 6G VRAM, mac os 10.13.6
