Page 4 of 8
Re: OctaneRender® for 3ds max® v3.06.4 - 4.40
Posted: Wed Sep 27, 2017 10:47 am
by paride4331
ABOUT TEXTURE ISSUE IN MATERIAL EDITOR - PLEASE READ HERE -
viewtopic.php?f=80&t=63108&start=10#p322790
Posted: Wed Sep 27, 2017 8:46 pm
by paride4331
@Goldisart@coilbook
that issue was fixed in SDK 3.07
Posted: Wed Sep 27, 2017 10:38 pm
by coilbook
starting since 4.40 version all slaves would suddenly stop rendering (no error messages) . Then a master must be restarted or slaves would not kick in rendering again. And usually when master rendering is canceled , after slaves stopped, 3ds max freezes and cannot be closed and pc must be restarted. version 4.39 never did this Hopefully you guys can trace this problem. No error messages though .
looks like it is just stuck on not updating slaves even though they are there
Posted: Thu Sep 28, 2017 8:59 am
by Goldisart
where can I get it ?
Posted: Thu Sep 28, 2017 10:40 am
by paride4331
Hi Goldisart,
Octane Render 3dsMax plugin SDK 3.07 will be released shortly.
Octane Octane Render SA 3.07 Test 6 is available here:
https://render.otoy.com/customerdownloa ... t6_win.zip
you can use it by exporting from 3dsMax to .orbx
Posted: Thu Sep 28, 2017 1:13 pm
by darkline
Hi
In this new version, if I have an alpha channel and choose to use a backplate (use viewport background), it displays fine when I first open the octane viewport; however if I lock the camera and change viewports then the background dissapears and only displays the checkered alpha. I have to close the octane viewport and re-open to get my background image back again.
Max 2014 here.
Posted: Thu Sep 28, 2017 1:28 pm
by paride4331
coilbook wrote:starting since 4.40 version all slaves would suddenly stop rendering (no error messages) . Then a master must be restarted or slaves would not kick in rendering again. And usually when master rendering is canceled , after slaves stopped, 3ds max freezes and cannot be closed and pc must be restarted. version 4.39 never did this Hopefully you guys can trace this problem. No error messages though .
Hi coilbook,
could you kindly make a test ?:
configure your master as follows:
win 7
uses 1 GPU ONLY for OS and monitor (EXCLUDE this GPU from Octane Render)
verify that all ethernet cables are at least cat6.
Posted: Thu Sep 28, 2017 2:02 pm
by paride4331
darkline wrote:Hi
Max 2014 here.
Hi darkline,
I do not think 4.40 has background problems in 3dsmax 2014, or I did not understand the issue.
Attached to a video clip. Is this correct?
Posted: Thu Sep 28, 2017 2:51 pm
by mikinik
paride4331, hi. Is this normal?
Only if I enable movable proxy checkbox everything works.
But there is no alembic sequence
Posted: Fri Sep 29, 2017 8:01 am
by paride4331
Hi mikinik,
I did this test with 2 .abc it seems to work, could you kindly share your .abc file (privately if you want) to check it out?
