Re: Suggestion needed for Render job graph
Posted: Thu Apr 26, 2018 10:29 pm
First and last frame settings in the batch render node(red box in the attachment) is the one you should be changing, this will be saved with the project.Tazan wrote:Hi Vijay,
I have yet another question on the Render job: at the moment when I put the frame ranges for each renders, it won't keep them in memory whenever I close the window.
Which is a bit annoying for small lists, but can be very annoying for big lists like the one in the following picture:
Also, I don't know Lua script language but is there a way to assign a frame range for each Batch render job by their name?
Best regards
The start and end frame in the render job dialog is the just resultant frames of a batch render job(not the animation timeline of the scene). This additional feature will be useful when you want to render selected frames of a batch render job node, especially when rendering interrupted.
