Page 4 of 19
Re: Version 3.04.1 (22.10.2016)
Posted: Sun Oct 23, 2016 10:24 pm
by aoktar
miohn wrote:btw I still have the problems with transparent/hidden objects in main 3D view.
Thought it was solved with 3.04.
Did I miss something or is there an option to solve this?
thanks
MIke
It's not a problem need to be solved just by me. There is a refresh BUG in C4D sdk for ALPHA enable custom materials. All materials get very frequent viewport update messages when i use this kind of option. So i have added some codes to avoid this very frequent update calls. But this is not working perfect on all cases. So I have reported this problem to some Maxon guy but don't know when will be fixed.
So what can you do? You can disable alpha for materials from settings->other panel. And it will be effective after you restart C4D.
Posted: Sun Oct 23, 2016 10:27 pm
by aoktar
miohn wrote:why not!
But like it was before, I can always zoom in to see the info more clearly.
Anyway - on option to choose is fine of course!
thanks
Mike
I made like this because my feel about that's a requirement for big renders and also some user requests.
Posted: Sun Oct 23, 2016 10:47 pm
by miohn
Hi Ahmet,
you mean to disable: "Alpha for Opengl previews"?
Cannot find a setting alpha for materials
thanks
Mike
Posted: Sun Oct 23, 2016 11:08 pm
by aoktar
miohn wrote:Hi Ahmet,
thanks
Mike
Yes.
Posted: Wed Oct 26, 2016 12:21 pm
by mrom
ok, that's weird - in my final render, the status bar got saved on the render - with a state of 9.4%. I can't even :D
the other renders got out fine without the status bar. wtf
edit: re-rendered, no status bar now. all good. weird nonetheless!
Posted: Wed Oct 26, 2016 1:41 pm
by miohn
Hi Ahmet,
not sure, if its because of my special scene I'm working on, but the rendering of
the layer masks takes as 3 or 4 times longer than the beauty and all other passes together.
And after starting to render the second layer mask, rendering is getting again slower and slower.
I'm on 3.04-R1
Are there any known issues with layer masks?
thanks
Mike
Posted: Wed Oct 26, 2016 2:25 pm
by aoktar
I'm on 3.04-R1
thanks
Mike
Do you know how it works? It makes additional run as much as how many of masks. How much masks do you talk?
Posted: Wed Oct 26, 2016 3:08 pm
by miohn
Hi Ahmet,
I know, that I cannot render out one mask only, because octane always renders the beauty as well, right?
But after thousands of renderings I never had the feeling, that masks takes soooo long.
You mean, that, if my beauty together with all other channels (reflection, matID etc...) is taking 2 hours f.e.
I have to wait for every mask 2 hours as well?
Nice to have 24 layer masks now ;)
Do you see any chance in the future to speed up rendering masks?
regards
Mike
Posted: Wed Oct 26, 2016 3:20 pm
by aoktar
It should not take soooo long. I belive you do something wrong. It's NOT CLEAR to me what are you doing exactly.
1- Scene should be ready on Octane side to get masks. And so beauty should be rendered. read next line...
2- There is two stages. First beauty/etc.. passes done. Second render out info passes. Masks are extracted from 3rd phase by using renderlayer operation for per maskID.
A- Beauty/reflect/diffuse/etc..... (time=until MAXSAMPLES)
B- All info passes together..... (time=until INFO_MAXSAMPLES)
C- Masks
c.1-Mask[1] +(time=until INFO_MAXSAMPLES)
c.2-Mask[2] +(time=until INFO_MAXSAMPLES)
c.3-Mask[3] +(time=until INFO_MAXSAMPLES)
c.n-Mask[n] +(time=until INFO_MAXSAMPLES)
3- TRICK: You can render beauty with MAXSAMPLES=1 if you need just masks.
No. All you have to make tricks. Do your magic.
Posted: Wed Oct 26, 2016 3:57 pm
by miohn
Hi Ahmet,
thanks to make this clear!
So maybe there is really an error in my scene, because, as I said
layer masks are rendering extremly slow in my case. I will check this.
And thanks for that trick with maxsamples=1.
I missed that !
regards
Mike
