Page 4 of 46
Re: OctaneRender for DAZ Studio 3.03.2 [TEST]
Posted: Mon Aug 08, 2016 12:42 pm
by face_off
Hi Paul
this morning I tried to render the same scene and this is the log of the crash :
07:59:44.264: +++++ Plugin running.08:32:30.458: CUDA error 999 on device 0: An unknown internal error occurred.
08:32:30.458: CUDA error 999 on device 1: An unknown internal error occurred.
08:32:30.459: -> failed to launch kernel (ptTrace1t)
08:32:30.459: -> kernel execution failed (report)
08:32:30.459: device 0: path tracing kernel failed
08:32:30.459: CUDA error 999 on device 1: An unknown internal error occurred.
08:32:30.460: -> failed to launch kernel (ptBrdf2)
08:32:30.460: device 1: path tracing kernel failed
08:32:31.025: Render engine failure occured! (WARNING)
08:32:33.470: Render engine failure occured! (WARNING)
I'm using the latest Nvidia driver, but had this problem even with other Nvidia driver.
Which NVidia driver are you using pls? Have you read the link in my signature regarding Nvidia drivers?
Posted: Mon Aug 08, 2016 1:00 pm
by AlfaseeD
face_off wrote:Which NVidia driver are you using pls? Have you read the link in my signature regarding Nvidia drivers?
Nvidia driver 368.81 and I will follow the instruction in your link!
Edit : do I really need to install this very old driver (358.50) ?
Posted: Mon Aug 08, 2016 2:17 pm
by AlfaseeD
Just a quick update : I removed the side panel of the case to let the vga cards "breath" better and temperatures never raises above the 73c.
The render reached 10000 samples without any problem ...
Posted: Mon Aug 08, 2016 11:25 pm
by face_off
That NVidia driver version is particularly buggy. 368.22 is a better option.
That indicates an overheating issue, however I thought overheating produced a different Octane Log message (Cuda error 715).
Posted: Tue Aug 09, 2016 12:30 pm
by AlfaseeD
Hi Paul,
I will try the 368.22 since I still have problems.
So the temperatures don't play a role in the crash.
I have these video cards since October 2016 and I never had these problems, but the last months is pretty unbearable. I cannot render "heavy" scene (2 character and 1 scenery).
Anyway, I will try the old drivers and I let you know!
Posted: Tue Aug 09, 2016 1:01 pm
by face_off
Hi Paul,
You can also try rendering with just one card - to try to isolate if there is a single card with a hardware issue. You can also try to underclock your cards a little.
Posted: Thu Aug 11, 2016 2:09 pm
by cyprine
AlfaseeD wrote: since October 2016
you time traveller ! tell us some news of the future :)
Re: OctaneRender for DAZ Studio 3.03.3 [TEST]
Posted: Fri Aug 12, 2016 12:23 am
by face_off
I have updated the installer at the top of this thread with:
3.3.3.24
- Compiled with Octane 3.03.3
- Change the VRAM reporting statistics so the meaning of the numbers is more obvious
Posted: Fri Aug 12, 2016 6:15 am
by hamer66
Thanks for the update.
Sadly i'm having a issue after installation, it seems te plugin can not be activated/load
Plugin failed to load!
Filename :
E:/3D Content/DAZ 3D/DAZStudio4/plugins/OctaneRender/plordazs.dll
Name :
plordazs
Author :
Unknown
Version :
0.0.0.0
Reason :
Library could not be loaded. File is not a valid DAZ Studio plug-in, or was made for a different version of DAZ Studio.
Reverting to the previous version works and it loads again. Any advice or could this be an issue with the installation package?
(i'm using the Daz version 4.9.2.70 )
Posted: Fri Aug 12, 2016 6:39 am
by swipswap
hamer66 wrote:Sadly i'm having a issue after installation, it seems te plugin can not be activated/load
Having the same issue for Daz 4.9.2.70, Windows 10
