Re: GTX 1080 Octanebench?
Posted: Fri Feb 10, 2017 2:47 pm
1080 renders the bench scene in PT at 32ms/s while 780 at 16-18ms/s so this is almos 2x faster.Chriz wrote:Yes i am just comparing rendering a scene with or without the 1080 ...
thank you for your comment, smichasmicha wrote: 1080 is almost 60-100% faster at OC than 780 - don't look at benchmark but measure speed in PT kernel for the same scene with parallel and tile samples set to max
desire wrote:thank you for your comment, smichasmicha wrote: 1080 is almost 60-100% faster at OC than 780 - don't look at benchmark but measure speed in PT kernel for the same scene with parallel and tile samples set to max
I did right that way - parallel and tile samples at max, one scene, identical parameters in PT kernel. And the same (main) PCI slot on the motherboard.
780 gives 7 minutes 01 sec
1080 gives 6 minutes 03 sec
ps.> octane 3.05.3
desire wrote:under load
core - 1987
memory - 1128
i'm like nub in tech specs ((smicha wrote:Memory - do you mean 4x1128? 4500mhz?
install msi ab and set memory clock to 5000mhz, core clock at boost to 2000mhz. Send screenshot from octane gpus settingsdesire wrote:i'm like nub in tech specs ((smicha wrote:Memory - do you mean 4x1128? 4500mhz?
here is screenshot https://yadi.sk/i/TK0zg3wH3DoaWs
Thank you, I'll try in a few hours and post result heresmicha wrote: install msi ab and set memory clock to 5000mhz, core clock at boost to 2000mhz. Send screenshot from octane gpus settings
