Page 4 of 5
Re: OctaneRender for SketchUp 2.24.2.1 - Test Release
Posted: Mon Jan 04, 2016 7:28 pm
by fivebythree
Also with Skatter, the components wont show unless you apply the proxy AND reGenerate the skatter. Is it compiling the data maybe? I had this problem once before. Matter of clearing previous beta installs of Octane, and keeping your nVidia drivers as up to date as possible.
Posted: Mon Jan 04, 2016 7:40 pm
by smicha
361.43
Posted: Tue Jan 05, 2016 8:36 pm
by CaptainCrowbar
Hi all,
I'm back from my vacation and working on the SketchUp plugin again. Thanks to everyone who has reported issues here, especially Notiusweb for his detailed report earlier in this thread. We hope to have some new builds for you soon.
Posted: Tue Jan 05, 2016 9:18 pm
by Seekerfinder
CaptainCrowbar wrote:Hi all,
Glad to hear that Captain. I am on Windows 8.1 about to upgrade to 10. I'd appreciate if you could look at the Win 10 crash issue as reported by others.
Best,
Hendrik
Posted: Wed Jan 06, 2016 1:42 pm
by Jorgensen
i'm trying to install the demo for sketchup 2016 on a colleagues computer, but i have some issues.
under install a second windows pops up that says, that there is already an install running and i need to close this.
when i start sketchup, octane does not start - i need to go to window>preferences>extensions> and select octanerender for sketchup.
but when i press the "octane interactive viewport" nothing happens.
i then open the ruby console and this error lists when i press "octane interactive viewport"
Error: #<NameError: uninitialized constant OctanePlugin::UI::RenderWindow::ExtUtils>
c:/users/fs/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/octane_render/lib/ui/renderwindow.rbs:31:in `set_html_file'
c:/users/fs/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/octane_render/lib/ui/renderwindow.rbs:23:in `initialize'
c:/users/fs/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/octane_render/lib/ui/renderwindow.rbs:133:in `new'
c:/users/fs/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/octane_render/lib/ui/renderwindow.rbs:133:in `init_dialog'
c:/users/fs/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/octane_render/lib/ui/renderwindow.rbs:145:in `show_window'
c:/users/fs/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/octane_render/lib/ui/toolbar.rbs:22:in `block in add_render_button'
c:/users/fs/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/octane_render/lib/ui/toolbar.rbs:9:in `block in create_button'
SketchUp:1:in `call'
i have tried to uninstall but that did not help.
does the demo requere the standalone version of octane? if so can this be a demo?
Posted: Wed Jan 06, 2016 7:32 pm
by CaptainCrowbar
Jorgensen, please try running our
uninstall utility. This should allow you to do a clean install afterwards.
Posted: Wed Jan 06, 2016 8:01 pm
by Jorgensen
thanks captain - i'll try that tomorrow.
jorgensen
Posted: Thu Jan 07, 2016 8:02 am
by Notiusweb
postby CaptainCrowbar ยป Tue Jan 05, 2016 8:36 pm
Hi all,
Aye Aye, Captain!...
Posted: Thu Jan 07, 2016 9:07 am
by Jorgensen
hi captian
not sure if i should create a seperate thread for this issue.....
i have uninstalled the pluging using the installer "octane_sketchup_2.24.2_2016_x64_demo.exe" and selected remove.
i then run the uninstall tool.
i checked the plugin folder, and octane has been removed.
i now install the plugin again, using octane_sketchup_2.24.2_2016_x64_demo.exe.
the installs runs, then a second window pops up in the background, that says "setup blocked...."
i have added some screens.
jorgensen
Posted: Thu Jan 07, 2016 3:36 pm
by fivebythree
Seekerfinder wrote:CaptainCrowbar wrote:Hi all,
Best,
Hendrik
Hey Hendrik,
I'm on windows 10, can't say that I'm having any problems. Albeit I did a complete fresh install of the system software. I'd suggest going that route if you're looking for the true winX experience.
Cheers,
Dom
