Page 4 of 9
Re: OctaneRender for AutoCAD 3.0.1 [TEST]
Posted: Tue Jan 05, 2016 4:03 pm
by guillerodriguezv
Correction is Octane Stand Alone Alpha 2.
Posted: Tue Jan 05, 2016 10:47 pm
by face_off
the only change that I see is that you can not use the plugin offline. Please check this because if the internet fails you can not use it. The same is for the Octane stand alone v3 beta.
Yes - I think this is deliberate, and only during the alpha and beta period. You should be able to use the plugin offline in the post-beta version.
Re: OctaneRender for AutoCAD 3.0.6 [TEST]
Posted: Tue Mar 01, 2016 11:58 pm
by face_off
3.0.6.13
- Compiled with Octane 3.0 alpha 6. Note the minimum Nvidia driver required is 353
Posted: Wed Mar 23, 2016 1:50 pm
by guillerodriguezv
Hi Paul,
I just realize that Autocad 2017 just realeased a few days ago, I have not tried yet, just to remind you if you tried it ,please check if supports AEC objects into the plugin... :D maybe I hope this time around.
Guillermo
Posted: Thu Mar 24, 2016 2:08 am
by face_off
In my experience, unless many people request a feature from Autodesk, it will not be implemented.
I will do a new installer for AutoCAD 2017 shortly after the Easter break.
Posted: Thu Mar 31, 2016 2:46 pm
by guillerodriguezv
Hi Paul
Any good news about Autocad 2017 Pluggin with AEC objects support ???
Guillermo
Posted: Thu Mar 31, 2016 9:45 pm
by face_off
I have downloaded and begun the plugin build process but not got everything working yet. I cannot see anything able AEC object support in the API changes, but will know more in the next day or so. http://hyperpics.blogs.com/beyond_the_u ... ation.html
Posted: Thu Apr 07, 2016 3:22 am
by face_off
I have been able to convert to plugin to work with AutoCAD 2017. And no, sorry, AutoCAD 2017 still does not support accessing the geometry for AEC objects. Is someone able to test the 2017 version pls?
https://render.otoy.com/customerdownloa ... _64bit.exe
Posted: Thu Apr 07, 2016 11:04 pm
by guillerodriguezv
Hi Paul
Installed and testing on Autocad 2017 ... :)
Posted: Mon Apr 11, 2016 5:57 pm
by guillerodriguezv
Hi Paul
I had been testing the plugin in Autocad 2017 and I had found some differences in triangulations comparing with Autocad 2014, both plugins lastest version (v 3.06).
regards
Guillermo
