Page 4 of 6
				Re: Lua script for texture animation?
				Posted: Sat Dec 13, 2014 11:00 pm
				by grimm
				It looks like there are several issues.  The first one and the easy one to fix is that the gamma was not being applied, so I have passed that through the node now.  The second problem is that when the environment is using the script node for it's texture the importance sampling doesn't do anything.  This is where you are getting your hard shadows, etc.  If you turn it off on a normal texture node it looks just like the script node.  It's either something I'm not setting up correctly for the texture or there is a bug.
				Posted: Mon Dec 15, 2014 12:49 am
				by Rikk The Gaijin
				Hopefully someone from Octane team will see this, and will help you figure it out.
				Posted: Mon Dec 15, 2014 12:59 am
				by abstrax
				Rikk The Gaijin wrote:Hopefully someone from Octane team will see this, and will help you figure it out.
We will have a look at this asap.
				Posted: Tue Dec 16, 2014 12:11 am
				by grimm
				This will be fixed in the next version.
				Posted: Tue Dec 16, 2014 8:55 am
				by ParviainenArk
				Sounds great, looking forward to updates!
				Posted: Fri Jan 02, 2015 4:07 pm
				by gardeler
				Great work Grimm! I wish I could do what you, (and everybody else that understands code), can. Would make my life so much easier.
Well, maybe next life.
Big kudos to you from DK!
				Posted: Sat Feb 14, 2015 6:50 pm
				by Refracty
just a question regarding the texture animation.
When I have a scene with no object animation and time slider. How can I save a batch of the duration of the texture animation?
				Posted: Sat Feb 14, 2015 8:04 pm
				by Refracty
				When I import a dummy alembic scene with a time slider animation I can render out the animation without a problem.
So it is working, but idially I need to find the timeslider button if there is no alembic scene loaded.
				Posted: Sat Feb 14, 2015 8:41 pm
				by Refracty
				Now I see. With the Ol Ready Cam Script it works fine even without a dummy alembic. Cool
				Posted: Sat Feb 14, 2015 10:36 pm
				by grimm
				Sorry I didn't respond sooner.  Good, you got it figured out, the script doesn't control the animation time, it just reacts to changes in the time or frame.  You need another script to control the time/frame changes for it to work right.
