Page 4 of 6
Re: Nodes and Nodegraphs in Lua.
Posted: Sun Jan 05, 2014 5:47 pm
by colorcurvature
hi, is it possible to change a node type from diffuse to glossy?
i tried using updateProperties() but my changes seem to get ignored
Posted: Sun Jan 05, 2014 7:16 pm
by stratified
No, once a node is created, you can't alter it's type anymore.
We can add replacement to the API. As a work around, you can create a glossy node, delete the diffuse node and reconnect the glossy node with everything the diffuse node was connected to.
cheers,
Thomas
Posted: Thu Jan 16, 2014 7:55 am
by Slide3D
Please help to write a script for automatic connecting mix material(macro) with objects material nodes
example of what i need in the picture
Posted: Thu Jan 16, 2014 7:49 pm
by stratified
Hi there,
I don't know the exact connection logic you're after but I can give you an example of how you connect a material to a mesh. The next snippet connects a material to all the pins of the mesh. You would need to write your own code to figure out exactly which connections to make:
-- connect the material to all the pins of the mesh
for pinIx=1,mesh:getPinCount() do
    mesh:connectToIx(pinIx, material)
end
Here's a full test script, just select a material and a mesh and run the script. Afterwards, all the connections should be made:
-- Select a material and a mesh
local mesh, material = nil, nil
-- figure out the selection of the material and the mesh
local selection = octane.project.getSelection()
if #selection ~= 2 then error("a material and a mesh needs to be selected") end
if selection[1]:getProperties().type == octane.NT_GEO_MESH and
   selection[2]:getProperties().type == octane.NT_MAT_DIFFUSE then
    mesh, material = selection[1], selection[2]
elseif selection[1]:getProperties().type == octane.NT_MAT_DIFFUSE and
       selection[2]:getProperties().type == octane.NT_GEO_MESH then
    mesh, material = selection[2], selection[1]
else
    error("a material and a mesh need to be selected")
end
end
before running the script
after running the script, all connections are made
I hope this steers you in the right direction.
cheers,
Thomas
Posted: Thu Jan 16, 2014 8:27 pm
by roeland
There is a script doing something similar with imported alembic scenes (Alembic and material assignments), maybe it can be adapted for mesh nodes too.
Roeland
Posted: Fri Jan 17, 2014 8:35 am
by Slide3D
Thanks Stratified
whether it is possible to select multiple materials?
Posted: Fri Jan 17, 2014 10:10 am
by Slide3D
I got several codes for each material
it is possible to unite in one code?
-- Select a limbs material and a mesh
local mesh, limbs = nil, nil
-- figure out the selection of the limbs material and the mesh
   selection[2]:getProperties().type == octane.NT_MAT_MIX then
    mesh, limbs = selection[1], selection[2]
elseif selection[1]:getProperties().type == octane.NT_MAT_MIX and
    mesh, limbs = selection[2], selection[1]
else
end
mesh:connectToIx(pinIx, limbs)
pinIx=17,mesh:getPinCount()
pinIx=18,mesh:getPinCount()
pinIx=23,mesh:getPinCount()
pinIx=24,mesh:getPinCount()
-- Select a toso material and a mesh
local mesh, torso = nil, nil
-- figure out the selection of the torso material and the mesh
    mesh, torso = selection[1], selection[2]
    mesh, torso = selection[2], selection[1]
else
end
pinIx=16,mesh:getPinCount()
mesh:connectToIx(pinIx, torso)
pinIx=19,mesh:getPinCount()
pinIx=20,mesh:getPinCount()
pinIx=21,mesh:getPinCount()
pinIx=22,mesh:getPinCount()
pinIx=28,mesh:getPinCount()
and for other mats
Posted: Fri Jan 17, 2014 10:29 am
by bepeg4d
hi thomas,
i have tried to convert your script for connecting an object layer node to all the pins of an object layer map node, but it works only for some pins and leaves always the others unconnected:
-- Select an object layer map and an object layer node
local Object_Layer_Map, Object_Layer = nil, nil
if #selection ~= 2 then error("an object layer map and an object layer node needs to be selected") end
if selection[1]:getProperties().type == octane.NT_OBJECTLAYER_MAP and
   selection[2]:getProperties().type == octane.NT_OBJECTLAYER then
    Object_Layer_Map, Object_Layer = selection[1], selection[2]
elseif selection[1]:getProperties().type == octane.NT_OBJECTLAYER and
       selection[2]:getProperties().type == octane.NT_OBJECTLAYER_MAP then
    Object_Layer_Map, Object_Layer = selection[2], selection[1]
else
    error("an object layer map and an object layer node need to be selected")
end
-- connect the object layer to all the pins of the object layer map
for pinIx=17,Object_Layer_Map:getPinCount() do
    Object_Layer_Map:connectToIx(pinIx, Object_Layer)
end
another question, the best would be to use an "object layer in" node but i'm not able to sobstitute the "Object_Layer" with the input version, where is the mistake?
-- Select an object layer map and an object layer in node
local Object_Layer_Map, Object_Layer_In = nil, nil
if #selection ~= 2 then error("an object layer map and an object layer in node needs to be selected") end
   selection[2]:getProperties().type == octane.IN_OBJECTLAYER then
    Object_Layer_Map, Object_Layer_In = selection[1], selection[2]
elseif selection[1]:getProperties().type == octane.IN_OBJECTLAYER and
    Object_Layer_Map, Object_Layer_In = selection[2], selection[1]
else
    error("an object layer map and an object layer in node need to be selected")
end
-- connect the object layer in node to all the pins of the object layer map
    Object_Layer_Map:connectToIx(pinIx, Object_Layer_In)
end
ciao beppe
Posted: Fri Jan 17, 2014 9:54 pm
by stratified
Slide3D wrote:I got several codes for each material
else
end
else
end
and for other mats
Yes, it's possible but now you would have 3 things in your selection and 6 different cases to consider...
I'm not sure what you're trying to accomplish with your script? You just want to make the connectios or is there a general rule to which connections to make? You could store a table mapping a material to all the pins on the mesh it connects to and loop over this to make the desired connections.
-- maps a matterial to all the pins
connections = { ["V6Torso"] = { "dzmat_Head", "dzmat_Neck", "dzmat_Hips", "dzmat_Torso" } }
for i,pinName in ipairs(connections["V6Torso"]) do
    print(string.format("connect material %s to pin %s", "V6Torso", pinName))
    -- do the connections here...
end
cheers,
Thomas
Posted: Fri Jan 17, 2014 10:08 pm
by stratified
bepeg4d wrote:hi thomas,
else
end
end
else
end
end
ciao beppe
Hi Beppe,
You only start making connections from pin 17 in your code (If you look at your picture, the first 16 pins aren't connected). You should make connections starting from pin 2 (The first pin takes a mesh so we should skip it):
for pinIx=2,Object_Layer_Map:getPinCount() do
end
The type for an input linker taking as input an object layer is octane.NT_IN_OBJECTLAYER not IN_OBJECT_LAYER.
This code should do the trick:
   selection[2]:getProperties().type == octane.NT_IN_OBJECTLAYER then
elseif selection[1]:getProperties().type == octane.NT_IN_OBJECTLAYER and
else
end
end
cheers,
Thomas
