Page 4 of 5
Re: OctaneRender® for 3ds max® v1.0 beta 3.00d[Test]
Posted: Mon Sep 10, 2012 5:34 am
by simmsimaging
Is there an issue with saving 32bit EXR files? I'm using the Max save dialog settings, set it for 32bit, but the EXR only contains 8 or 16bit data when I look at it in Photoshop. The file says it's 32bit, but there is no linear data in the highlights from what I can see. SHould it be working or is this a limitation?
b
Posted: Mon Sep 10, 2012 7:16 am
by Karba
simmsimaging wrote:Is there an issue with saving 32bit EXR files? I'm using the Max save dialog settings, set it for 32bit, but the EXR only contains 8 or 16bit data when I look at it in Photoshop. The file says it's 32bit, but there is no linear data in the highlights from what I can see. SHould it be working or is this a limitation?
b
Have you switched off
apply for output option in imager settings?
Posted: Mon Sep 10, 2012 7:24 am
by simmsimaging
I was using the camera settings - as per the other thread - but see that it is on in the render dialog. Does the tonemapping also clamp? Is it possible to have the tone-mapping done for the colour/contrast, but maintain the image in float?
b
Posted: Mon Sep 10, 2012 7:28 am
by Karba
simmsimaging wrote:I was using the camera settings - as per the other thread - but see that it is on in the render dialog. Does the tonemapping also clamp? Is it possible to have the tone-mapping done for the colour/contrast, but maintain the image in float?
b
This option works any way.
It is impossible to have unclamped colors with tone mapping.
Posted: Mon Sep 10, 2012 7:42 am
by simmsimaging
Karba wrote:This option works any way.
Not sure what this means?
Karba wrote:It is impossible to have unclamped colors with tone mapping.
I understand. So does that mean I have to choose the linear preset or just uncheck the apply tonemapping box in the rollout?
Posted: Mon Sep 10, 2012 8:05 pm
by suvakas
Hi all,
I wanted to report a bug.
Texture map is not rendered when there are unicode characters in it's dir path.
It's a bit strange cause i'm using Max 2013 here and Max SDK should have full unicode support now?
Anyway. Should be an easy fix.
Suv
Posted: Mon Sep 10, 2012 9:51 pm
by suvakas
Most of my textures render out gray.
What could be the reason? (not related to unicode bug)
[edit]
I had to set everything to proxy, then textures re-appeared.
If i removed proxies colpetely, then most of my textures went back to gray. Strange?
Suv
Posted: Mon Sep 10, 2012 11:22 pm
by merid888
thank you MaTtY631990, i'll try using this lights, i think so is like sky portal, right ?
regards
p.d. do you speak spanish ?
Posted: Tue Sep 11, 2012 4:26 pm
by MaTtY631990
merid888 wrote:thank you MaTtY631990, i'll try using this lights, i think so is like sky portal, right ?
regards
Sorry,am afraid not. Although I can use a translator tool if this helps.
Posted: Sat Sep 15, 2012 12:21 am
by emihich
Hi, I amCompletely Newbie to Octane , have experience with MR, Maxwell and a litlle Vray.
Amazing interactive ,the Octane demo.
I've Instaled this version of the plugin for 3ds max 2013 ,and licensed all right.
I could go for an official version, instead of a Beta, Should I ?
However I can't see any render image while rendering the files.
I noticed there is an option for Octane window and the native render window for Max .
Both are black.I was also expecting your plugin to open Octane, and it just didn't happen
Do you have a tutorial link you could send me , please ?
I am sure it's all happening because I am a complete Newbie to this plugin.
Don't send me a link to the manual, it didn't help .
