Page 4 of 8
Re: Octane Cornell Box and other various test models !
Posted: Tue Jan 19, 2010 7:09 am
by Chris
Sam wrote:Im so lazy
(ill make an account)
I readed the PDF and that gave me ideas, thanks
The markers are great feature.
Also the lighting room is good.
But there's no subsurface bar and markers are not quite the same thing.
Subsurface bar change size when the IOR change. The markers does but not by much.
Ill try to not copy everything
But that's indeed a good material ball.
Oh my god bubbles (just to see that everyone works)
How do you manage to do UV if there's bubbles inside the solid
Im currently making a sweet subsurface bar.
(edit: currently going to sleep
Great you got some ideas from it Sam
I Won´t lay out any UV`s for the bubbles, only for the rest of the mesh. Bubbles will only be visible when you use a transparent material anyways. In general transperant materials dont need UV`s as they usally dont have any textures. It wont be a problem
I made a light room like that yesterday that we can place your nice material ball in if you like. When both Maxwell and Thea uses it i think it is a good choice. I will test my light room in a unbiased render (with mesh emitters) today and post results.
Posted: Tue Jan 19, 2010 10:50 am
by Sam
Hehe double post.
Check your PM inbox Chris.
Im currently busy.
Thanks for your help.
@Radiance
If you want the same ball I sent to Chris just ask ill forward it to you
Posted: Wed Jan 20, 2010 5:56 pm
by radiance
sorry guys, but i've been very busy coding and there's now heaps of posts everywhere with this ball.
is it finished ?
if it is, can someone send me the final version ? as a obj+mtl ?
so i can clean it up and add it to octane ?
i need the object, without the 'nose',
on a slope floor (like chsphere:
http://images.google.be/images?q=cgsphe ... =nl&tab=wi)
the inside ball and footpiece need to be a lightgrey plastic.
Radiance
Posted: Wed Jan 20, 2010 5:57 pm
by radiance
and the cornell box also
Radiance
Posted: Wed Jan 20, 2010 6:52 pm
by Chris
I can provide a custom made hdri map for light setup if you like? Sam and i have talked a bit about it, and he sayd you would probaly want a hdri for the setup?
Posted: Wed Jan 20, 2010 7:06 pm
by radiance
no,
leave that up to me.
i'll do the lighting.
there's no room in my binary to place HDRI maps.
Radiance
Posted: Wed Jan 20, 2010 7:27 pm
by Chris
I also have a simple light box ready to use with mesh emitters
Posted: Wed Jan 20, 2010 7:37 pm
by Chris
Heres Sams material ball inside the light room with mesh emitters:
Not rendered in Octane, but with a nother unbiased engine that have mesh emitters
Ps: Floor grid is not final
Posted: Wed Jan 20, 2010 7:47 pm
by radiance
i think the scene is good but:
- lose the 'nose', it makes it look a bit silly
- the footpiece (eg cylinder that's on the floor) it too wide. maybe remove the outer rim and reduce the outer rim diameter of the grey piece of plastic.
the current dimensions are a bit off,
the support/footpiece is too large.
Radiance
Posted: Wed Jan 20, 2010 7:50 pm
by Sam
Radiance, its just because Chris didn't said all the details.
Stop replying for now you are replying to things we already modified
Sorry for the weirdness
Im writing a message right now, replying to another of your message
