Re: Version 3.00 - Alpha6.3 (12.04.2016) - Preview version
Posted: Mon Apr 18, 2016 9:28 pm
				hard crash?Josef wrote:sorry if this is mentioned before , but often when connecting a new image node to a material channel , c4d hard crashes.
Community Forums for OTOY Customers
https://render.otoy.com/forum/
meant c4d will stop working (the normal windows pop-up) , it's different from the one usually create a bug report fileaoktar wrote:hard crash?Josef wrote:sorry if this is mentioned before , but often when connecting a new image node to a material channel , c4d hard crashes.
Sorry this is not giving any idea to start. You should describe that as i asked in first page with red letters. Thanks!Josef wrote:meant c4d will stop working (the normal windows pop-up) , it's different from the one usually create a bug report fileaoktar wrote:hard crash?Josef wrote:sorry if this is mentioned before , but often when connecting a new image node to a material channel , c4d hard crashes.
RR has problems on A9. I'll disable it if i release a version.cfrank78 wrote:I am on a huge project with volumetrics with complex textures. Region render is a must have this time. Any Idea when V3 Alpha 9 comes? You said yesterday and i checked every hour but still no release. Any scedule when you release? THX!
Chris!
This message sounded like its an SDK error, which is with V9 fixed and that you will release V9 on monday! Soory......really my bad that i asumed that i will have a working region render Version on mondayaoktar wrote:It's not working on A6 SDK. I'll release A9 on monday.lucioing wrote:Hi Ahmet!
Thank you for you great job, a always...
What about render region? It seems it doesn't works... If I do select a region, in LV the rendering it is done on ALL window...
L.
Can you explain how do you use it?bertritude wrote:hI guys,
thanks for the .vdb tricks.
I tried to use the cloud package and it works only with the .vdb folder with a path without special characters ("é,è" in particular).
If I put it in my library, it don't work.
did you try to use it from your library ?
Bertrand
try on fully english chars also don't use '-é etc.. It's fixed.Newermax wrote:Dear Ahmet! A small request. In the "Alpha 6.3" does not work animation texture. Please make sure it is working properly in the next version. Thank you.
