Page 21 of 25
				Re: Version 3.06.2 - Latest stable
				Posted: Mon Aug 21, 2017 8:24 am
				by ralf_breninek
				aoktar wrote:Weezer wrote:Nice to see you have Forester and RealFlow on your test rig
Yes both are on my interest for better support.
Nice to read you are looking into Forester too, have bought it last year and only used it twice, gotta check it out again.
				Posted: Mon Aug 21, 2017 8:44 am
				by Ron
Better Forester Support. Very nice!
				Posted: Tue Aug 22, 2017 10:43 pm
				by Inky
				Otoy, you guys are doing a great job with your updates lately!
Any word on when displacement will stop pulling apart polygons on geometry? And also, when it will start accepting different projections types?
Keep up the amazing work!
				Posted: Thu Aug 24, 2017 11:06 am
				by aoktar
				I'm dropping a test build just for getting some early feedbacks. Only windows/regular build. I'll make detailed explanations and samples soon in seperate topic.
CHanges for 3.07
- Volume object update detection
- Node editor: Undo/redo update issue on embedded editor with node parameters
- Fix: Crashes with Meshno>3 on Object tag
- Scatter object: Animated/deformed objects support on distribution slot. Fix wrong weights on effectors. Fix unnecessary calculation on camera navigation. Instance color support. Shader effector UV support.
- Initial colorID support for particles/scatter object.
- Fix: Broken "-exportORBX" commandline parameter.
- Better Camera MotionBlur processing for fixing some issue of CamMoblur detection.
- Fix: Triplanar bug on handling of initial channel.
- Triplanar node, single texture improvement.
- Change: Internal diffuse color changed from gray to black for internal material of Light Tags. It may cause a small amount difference on results of illumination effect.
- Floor object support added. Tiling from texture tags will not work. So use transform nodes in textures for scaling.
- Node Editor: Solo mode for textures
- more.....
Plugin:
https://render.otoy.com/customerdownloa ... 3a-win.zip
Standalone:
viewtopic.php?f=33&t=62636
New core features:
viewtopic.php?f=33&t=62395
				Posted: Thu Aug 24, 2017 12:38 pm
				by Studio21
				Ty Ahmet! will start testing right away
Looking forward for some simple example scenes demonstrating the new X-particles and scatter features
PS: Do i need to install the latest standalone to test this?
Best,
Guy
				Posted: Thu Aug 24, 2017 1:16 pm
				by aoktar
				Studio21 wrote:Ty Ahmet! will start testing right away
Best,
Guy
Instance color on material and switch to particles and link an emitter. Then use objecttag, select a particle object with this material.
				Posted: Thu Aug 24, 2017 2:58 pm
				by Studio21
				Works great so far Ahmet..ty
what is the instance Range node for?
				Posted: Thu Aug 24, 2017 3:40 pm
				by eyeonestudio
				Hi Dear.. WoW R19.. Thanks Ahmet....
I believe you will add more C4D shader slots to the node editor.
				Posted: Thu Aug 24, 2017 3:52 pm
				by Studio21
				The list of nodes is getting longish
Time to consider a small search function
Best,
Guy
				Posted: Thu Aug 24, 2017 4:56 pm
				by zinogino
				Downloaded and tried it on a scene I'm working on.
The new version is pushing my GPU's to 100% which is never done before on the previous version.
