Sorel wrote: Fri Jul 17, 2026 7:31 pm
I think I found a bug with the rgb image node. If it also has rgb color/gaussian set as the power, it you try changing the value to any other color it will not take that color.
Hey Sorel, I'm seeing the same thing. I think it might not be a bug but a change in Octane 2026 though, because when I try it in Blender with the 2026 addon it has the same behavior. Guess they want you to tint your textures with a multiply node vs plugging directly into the texture's power input.
Ah ok. I will adjust then.
Re: OctaneRender for DAZ Studio 2026.4 - 410 [Stable]
Posted: Wed Jul 22, 2026 11:42 am
by MFindt
Hello,
I hope here is still someone who uses the plugin and can help me.
I installed the v410 and can not find Octane in Windows/Panes to select.
Can you help me please.
Thnaks,
Michael
Thnaks,
Michael
Please check under the Render pane on the menu. You should see the options there. Also press F12 for the interface to pop up.
This is of course once you confirm that the plugin is active under Help installed plugins.
Thnaks,
Michael
Yes, its there !!! Thank you so much.
May I as k you if you know if the plugin runs also in Daz Studio 6?
Thnaks,
Michael
No, they will need to build a plugin for Daz 6
Posted: Mon Aug 17, 2026 6:39 pm
by Tugpsx
Here is a link to my YouTube video on saving environment presets in Octane Render for Daz Studio.
In the past we spoke about re-enabling the ability to edit the presets without having to create new one. I remember the reason for locking them was that users complained about messing up their saved presets, so it was locked.
Posted: Tue Oct 06, 2026 3:34 pm
by filipe_sheepwolf
Thank you for adding VDB support! It's so great to see this finally working!
Posted: Tue Oct 06, 2026 10:34 pm
by BK
filipe_sheepwolf wrote: Tue Oct 06, 2026 3:34 pm
Thank you Filipe,
Yes, Jim worked on it real fast!
A big thanks to him!
