Page 3 of 3
Re: Octane 2026.2 for Cinema4D - v1.9.0
Posted: Thu Apr 16, 2026 7:56 am
by bepeg4d
catelloo wrote: Wed Apr 15, 2026 1:26 pm
Octane user since 2017 but first post here.
Posted on FB group but I was not able to find a solution to a similar problem I've seen on this thread and on the group.
No matter what Studio Driver I use (even after DDU clean install) I'm not able to export both Main and DeMain in any format from 1.8.3 onword. Last version writing a Denoised Bauty for me is 1.8.1.
I'll link the discussion on the post here with all the details so I won't need to write a wall of text. Hope is not against the forum rules.
https://www.facebook.com/groups/OctaneRender/permalink/3366834966826891/
Have you installed ComfyUI on your machine, even in portable mode?
ciao,
Beppe
Posted: Thu Apr 16, 2026 10:30 pm
by catelloo
bepeg4d wrote: Thu Apr 16, 2026 7:56 am
ciao,
Beppe
Ciao Beppe.
Yes, I have. In portable withing an environment with py and CUDA toolkit. It worked for months on the same machine with other versions of octane.
I've already uninstalled everything about it tho and retested. Still the same error with the new octane version.
Posted: Mon Apr 20, 2026 8:55 am
by martinzip
Dear Beppe, dear Chris
once again I want to ask, if we could expect to have Octane render nodes for macos again? Would be very nice regarding the big VRAM and the actual very good stability of octane renderer under macos.
In June M5Ultra is expected and on the long run next M processors will have a render power of a rtx5080 or more...so it will be worth to put even laptops into the render network...
Thank you very much for your great work so far!
Kind regards from Cologne
Martin
Posted: Tue Apr 21, 2026 9:48 am
by bepeg4d
martinzip wrote: Mon Apr 20, 2026 8:55 am
Martin
Hi Martin,
I'm with you that a macOS Render-Node version would be very nice to have, but this doesn't depend from Chris or me, but from OctaneRender core.
Happy Mac GPU rendering!
ciao,
Beppe
Posted: Tue Apr 28, 2026 7:54 am
by martinzip
Hello Beppe,
could you please post a link to the core team, so that I/we can discuss with them?
kind regards from sunny cologne
Martin
Posted: Thu May 07, 2026 9:32 am
by ChrisHekman
martinzip wrote: Tue Apr 28, 2026 7:54 am
Hello Beppe,
Martin
viewtopic.php?p=442400
Posted: Tue May 12, 2026 8:56 am
by 19Nik90
Hello,
Inside the Octane Camera Tag, every time I try to enable the Imager, Cinema 4D crashes.
I'm using the latest Cinema 4D 2026.2.0 version and tha latest Octane render plugin 1.9.0.
I've attached the Bugreport file and also a Cinema 4D file that occur the problem.
Thank you
Nik
Posted: Tue May 12, 2026 2:05 pm
by ChrisHekman
19Nik90 wrote: Tue May 12, 2026 8:56 am
Hello,
Thank you
Nik
I found the crash. It will be fixed in the next build.
For now you can avoid the crash by making sure the octane LV window is open before you enable imager.
Posted: Tue May 12, 2026 2:40 pm
by 19Nik90
ChrisHekman wrote: Tue May 12, 2026 2:05 pm
Hello,
Thank you
Nik
Ok perfect!
Thank you
Nik
