Page 3 of 8
Re: Any news about an update for the exporter ?..
Posted: Tue Sep 20, 2011 3:07 pm
by scratch33
Hello holocube,
You can simply export an *.obj with the standart exporter of the modeler disabling zbrush option.
The smoothing will be ok in octane.
Posted: Tue Sep 20, 2011 6:54 pm
by holocube
that would then be modeler only right?
during the HC beta they added obj export from layout but didnt include vertex normals.... which I fogged but was ignored..
Posted: Tue Sep 20, 2011 7:02 pm
by holocube
I tried exporting a sphere from modeler, checking the .obj it did write the normals. In octane I end up with this:
(smoothing is turned on in material)
haven't exported .obj from modeler to octane before, what settings are you using?
Posted: Tue Sep 20, 2011 7:50 pm
by scratch33
Ops,
sorry, I have the same result that you...
Strange, some time ago, to passtrough the smooth problem, I was exporting from modeler
and it works just fine.
My problem was on glossy materials reflecting the environement...
Posted: Tue Sep 20, 2011 8:01 pm
by holocube
Actually I got the same render with Francks sphere.
Could anyone export from another working package, even a simplier object would be great. Then share the .obj
Posted: Tue Sep 20, 2011 8:07 pm
by scratch33
Ok,
I have just tryed with an old scene :
The first is from modeler, the second from layout. lw 10.1 with octane 2.52
Posted: Tue Sep 20, 2011 8:25 pm
by scratch33
And here are the simplified files(only glass):
Posted: Tue Sep 20, 2011 8:28 pm
by holocube
could you try attached .p. x64
set export options to:
export proporties: normal
write point normal: off
Posted: Tue Sep 20, 2011 8:40 pm
by scratch33
Not bad...
I can now switch on/off the smooth option in octane and there is a difference between the two. But they still are strange artefacts on the surface
Here are the result picture:
1) from modeler
2) from your new plugin
Posted: Tue Sep 20, 2011 10:33 pm
by face
holocube wrote:I tried exporting a sphere from modeler, checking the .obj it did write the normals. In octane I end up with this:
Exact this image isn“t a export issue, this is a problem with the renderalgorithm, called "Terminator".
http://refractivesoftware.com/forum/vie ... tor#p49173
face
