Page 3 of 3
Re: X Particles "Render Geometry" doesn't work when use GROUPS
Posted: Fri Oct 07, 2022 8:31 am
by rudybertazzo
Well, that fast fast! I'll gladly test this new build, could you attach the studio version of the plugin? Thanks!
Posted: Fri Oct 07, 2022 9:44 am
by aoktar
rudybertazzo wrote:Well, that fast fast! I'll gladly test this new build, could you attach the studio version of the plugin? Thanks!
here's:
https://render.otoy.com/customerdownloa ... t1-win.rar
Posted: Fri Oct 07, 2022 4:20 pm
by rudybertazzo
Hi Aoktar, I'm still getting a licensing error with this build, is it possibile this is still the Enterprise version and not the Studio one? Thanks.
Posted: Fri Oct 07, 2022 5:55 pm
by aoktar
rudybertazzo wrote:Hi Aoktar, I'm still getting a licensing error with this build, is it possibile this is still the Enterprise version and not the Studio one? Thanks.
Wrong dlls, use this fixed build. Disable new "Use groups" in particle rendering of object tag.
Posted: Fri Oct 07, 2022 6:25 pm
by rudybertazzo
THANK YOU, I can confirm that by disabling the new "Use groups" checkbox it is possibile to render all the objects in the tag, regardless of Group number, exactly like it was in Octane 2020!
Thanks again for your time and super fast response, really appreciated.
Posted: Fri Oct 07, 2022 6:29 pm
by aoktar
Great to hear! Probably OFF case is better to use as default. Then people can enable it for group support.
Posted: Fri Oct 07, 2022 6:31 pm
by rudybertazzo
Yes, I think that OFF as default could be more intuitive for most users, since it just render all the objects you put in the tag for that Emitter.
Posted: Mon Oct 10, 2022 7:59 am
by Tim0042
A quick thanks to all involved! : ) I was just running up against this issue last Friday and this new download solves it. Thx!
Posted: Fri Oct 14, 2022 12:46 pm
by sdimaging
I may be missing something, in 2021.1.6 R4 this "disable groups" doesnt show up in the particle object tag - if you use multiple geo though it designates secondary instances to the secondary object in the list, is this to say you can only instance a single piece of geo per group if there are multiple groups??
I'm a bit lost and confused.
Posted: Fri Oct 14, 2022 3:26 pm
by aoktar
sdimaging wrote:I may be missing something, in 2021.1.6 R4 this "disable groups" doesnt show up in the particle object tag - if you use multiple geo though it designates secondary instances to the secondary object in the list, is this to say you can only instance a single piece of geo per group if there are multiple groups??
Yes missed that we are talking about a test R5 build. See previous messages here
