Page 3 of 4
Re: OctaneRender® for 3ds max® v2020.1.4 - 10.14
Posted: Thu Aug 13, 2020 10:05 am
by samsue
this is a very annoying problem
Posted: Thu Aug 13, 2020 11:19 am
by samsue
this is the second time I've reported this problem after 1 month ...
Posted: Thu Aug 13, 2020 3:11 pm
by HHbomb
I had more then 5000 instances in a layer. The layer is hidden.
When I run octane viewport all become sluggish, slow,... more then several seconds to open quad menu,....
I delete all objects= all is ok.
It is strange that hidden objects can slow down max when using octane viewport.
Posted: Fri Aug 14, 2020 12:26 am
by neonZorglub
Hi HHbomb,
I guess you didn't turn on the Quick mode..
Without Quick mode, all objects are regularly checked, to see if something changed.. for example change from hidden to visible.., so that can be very slow with many objects..
With Quick mode enabled, changes are handled when detected; There used to be some types of changes that were not detected correctly, but I think all have been fixed by now..
It might be time that I remove this option, and keep it always enabled..
HHbomb wrote:Hi,
Posted: Fri Aug 14, 2020 6:49 am
by samsue
neonZorglub , if you don't care, at least you could give a little bit of a response "I don't know what this is or this is something 3ds max not octane related"
at least it would keep a good impression
Posted: Fri Aug 14, 2020 6:55 am
by paride4331
samsue wrote:neonZorglub , if you don't care, at least you could give a little bit of a response "I don't know what this is or this is something 3ds max not octane related"
Hi samsue,
at the moment we could not reproduce that issue, we're investigating around.
Are you using 3dsMax 2021? Release?
Posted: Fri Aug 14, 2020 7:10 am
by samsue
Hi paride4331,
3DS Max - 2021.1 / 23,0 -23.1.0.1314
Whenever I'm rendering with OctaneRender Viewport this issue occurs. It's also something new to me this issue, but it's hard to know whether it's because of the nvidia driver, 3ds max or octane ...
Posted: Fri Aug 14, 2020 7:41 am
by mbetke
[QUOTE]I guess you didn't turn on the Quick mode..
It might be time that I remove this option, and keep it always enabled..[7QUOTE]
Removing it would be nice. But please fix the UVW-Map Modifier. Because if I change the scaling I need to update the whole scene with Quickmode on.
Posted: Fri Aug 14, 2020 8:28 am
by paride4331
samsue wrote:Hi paride4331,
Hi samsue,
I have not your issue using 2021.1 / 23,0 -23.1.0.1314 version.
Could you share a scene where the issue could occurs?
Posted: Fri Aug 14, 2020 8:41 am
by HHbomb
Yes please NZ. It would be nice ( it would work as before ) but for exemple Lights are not updated, sun, some textures, etc. so I never use Quick mode...
