Page 3 of 3
Re: Houdini 18.0.499 does not start
Posted: Sat Jun 20, 2020 8:33 am
by juanjgon
jandress wrote:The 499 Octane will not start in the 499 build. Error message box on Houdini startup:
"(1114)Couldn't load C:/Users/john/Documents/houdini18.0/Octane_2020.1.2.0_Houdini_18.0.499_vr_Win64/dso/HoudiniOctane_18.0.499_vr.dll
This is probably because this file was intended for use with a different version of Houdini."
Update: the 460 version fails with a similar error.
This seems a configuration problem. Can you please attach the houdini.env file that you are using? The problem can be a mistake in the PATH variable, or trying to work with a wrong plugin build for your Houdini version.
Posted: Sat Jun 20, 2020 9:24 pm
by jandress
# Houdini Environment Settings
# The contents of this file are read into the environment
# at startup. They will override any existing entries in
# the environment.
# The syntax is one entry per line as follows:
# VAR = VALUE
# Values may be quoted
# VAR = "VALUE"
# Values may be empty
# VAR =
# Example:
# HOUDINI_NO_SPLASH = 1
HOUDINI_NVIDIA_OPTIX_DSO_PATH = C:/Users/john/Documents/houdini18.0\optix
HOUDINI_PATH = "$HOUDINI_PATH;&;C:\Users\john\Documents\houdini18.0\Octane_2020.1.2.0_Houdini_18.0.499_vr_Win64;&"
PATH = "C:\Users\john\Documents\houdini18.0\Octane_2020.1.2.0_Houdini_18.0.499_vr_Win64/bin;$PATH"
HOUDINI_DSO_ERROR = 2
Posted: Sat Jun 20, 2020 9:28 pm
by jandress
OS Name Microsoft Windows 10 Pro
Version 10.0.18363 Build 18363
Nvidia Driver Version 445.87
GTX780
HP Z800 2xX5670 / 48GB
Houdini 18.0 Build 499
After it didn't work the first time I created a fresh houdini18.0 folder, still the same error message. The toolbars show up but adding a node brings:
The attempted operation failed. Invalis node type name
Details:
Traceback (most recent call last):
File "Add_Octane_ROP", line 1, in <module>
File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.499/houdini/python2.7libs\roptoolutils.py", line 10, in createRenderNode
rop = hou.node('/out').createNode(rop_type, exact_type_name=True)
File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.499/houdini/python2.7libs\houpythonportion\ui.py", line 927, in decorator
return func(*args, **kwargs)
File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.499/houdini/python2.7libs\hou.py", line 9379, in createNode
return _hou.Node_createNode(*args, **kwargs)
OperationFailed: The attempted operation failed.
Invalid node type name
Octane 2020.1.0.8 worked fine in build 460.
Posted: Mon Jun 22, 2020 8:22 am
by juanjgon
I wonder if this could be a problem with the NVIDIA drivers or something like that. Do you know if the Octane 2020.1.2.0 Standalone works fine in your system? You can download it here:
viewtopic.php?f=15&t=75100
Posted: Wed Jul 01, 2020 11:38 pm
by jandress
I have now tried everything including a fresh installation of windows/nvidia/houdini/maya & octane. Octane 2019 standalone or plugins will run. Octane 2020 standalone or plugins will not run. Even as a temporary solution I can't use Octane 2019 for houdini as it does not have a build for houdini newer than 18.0.287 and Octane 2019 for maya does not seem to support Maya 2020 at all.
The only thing I can think of is that for some reason the new windows Octane builds require a cpu instruction not present on my socket 1366 xeon X5670 even though the requirements page lists no cpu hardware requirements. (non-octane cuda runs fine, cycles, resolve etc).
Can anyone confirm that they have been able to run Octane 2020 on a X5670 generation Xeon on Windows?
Posted: Thu Jul 02, 2020 7:31 pm
by galleon27
jandress wrote:I have now tried everything including a fresh installation of windows/nvidia/houdini/maya & octane. Octane 2019 standalone or plugins will run. Octane 2020 standalone or plugins will not run. Even as a temporary solution I can't use Octane 2019 for houdini as it does not have a build for houdini newer than 18.0.287 and Octane 2019 for maya does not seem to support Maya 2020 at all.
People have been reporting problems with older CPUs. Its a Octane Core issue is seems. You should probably go ask in the Standalone thread
viewtopic.php?f=24&t=75172&start=10
Posted: Fri Jul 03, 2020 8:02 am
by juanjgon
Yes, I think that there is a problem with this latest build in some old CPUs. The core team is aware of this limitation, and they will try to fix it for the next build, if possible.
