Page 3 of 3
Re: Proxies workflow
Posted: Wed Mar 03, 2021 11:20 am
by face_off
Hesekiel2517 wrote:Hi Dingbat,
i think the solution to your problem is to create a lowpoly Version of your highres Mesh (or a simple cube with the right dimensions) to use them in the Meshlayer you use as a proxy. So you can see your lowres Meshes in the viewport, but Octane will pick up your prepared Orbx for rendering.
Yes, you can use a Modo cube Mesh Item and attach the ORBX proxy to it, so you can see the positioning in the Modo OpenGL window.
Posted: Wed Mar 03, 2021 11:47 am
by Dingbat
face_off wrote:Hesekiel2517 wrote:Hi Dingbat,
i do that sometimes, but it's just wasting time on really tedious stuff if you have a large library of trees and plants
and also if i need to switch to the MODO render engine for any reason, the render will be completely different as MODO will only render the low poly versions.
attaching the ORBX to a deferred mesh, in the same way you can attach it to a regular mesh would be a great compromise, and shouldn't be too difficult to add?
Posted: Thu Mar 04, 2021 3:14 am
by face_off
Dingbat wrote:face_off wrote:Hesekiel2517 wrote:Hi Dingbat,
I am really sorry, but this is not an easy feature to add, and there is a long backlog if other features that I need to implement, so it's not something I can do in the short to medium term.
Posted: Thu Mar 04, 2021 4:37 pm
by Dingbat
face_off wrote:I am really sorry, but this is not an easy feature to add, and there is a long backlog if other features that I need to implement, so it's not something I can do in the short to medium term
fair enough. thanks for considering
