Page 3 of 4
Re: OctaneRender 2019.1 for Houdini Production build 2019.1.2.0
Posted: Tue Nov 19, 2019 3:25 pm
by juanjgon
juanjgon wrote:Nope, sorry, I was talking about a future version. Currently, I think that it is not possible because in the Houdini plugin Octane doesn't have a proper "noisy" pass in the render target, so I need to add some kind of workaround.
I've added this feature for the next plugin build.
Posted: Tue Nov 19, 2019 3:48 pm
by aLeXXtoR
juanjgon wrote:juanjgon wrote:Nope, sorry, I was talking about a future version. Currently, I think that it is not possible because in the Houdini plugin Octane doesn't have a proper "noisy" pass in the render target, so I need to add some kind of workaround.
Great, thanks!
Posted: Tue Nov 19, 2019 3:57 pm
by WoutTgh
juanjgon wrote:WoutTgh wrote:the denoiser is applied randomly to a rendered sequence of frames it seems. Some frames are denoised, others are not. Any thoughts on this ? Thank you !
Sorry, I have not seen this problem before. Are you talking about the denoising in the MPlay preview or in the final output files? If you could share a scene with this problem it could help a lot.
I've seen this happen with frames rendered to disk and in Mplay. Something similar seems to be happening to the post processing. Some frames have it, some frames don't.
Can I email you a wetransfer link with the scene ? it's 100mb because I'm using a particle cache ( reduced to 10 frames)
Posted: Tue Nov 19, 2019 9:32 pm
by juanjgon
WoutTgh wrote:Can I email you a wetransfer link with the scene ? it's 100mb because I'm using a particle cache ( reduced to 10 frames)
Sure, you can use my email
[email protected]
Posted: Tue Nov 19, 2019 11:40 pm
by WoutTgh
I sent you a wetransfer !
Posted: Wed Nov 20, 2019 2:49 pm
by juanjgon
WoutTgh wrote:I sent you a wetransfer !
I'm sorry, but I can't reproduce this problem here. I wonder if somehow you could be running out of GPU memory to process the denoising or if it could be a drivers issue. In any case, later this week I'll release a new plugin build including the latest 2019.1.4.0 core. If you still have this problem with this new build, please let me know to further investigate it.
Posted: Wed Nov 20, 2019 3:10 pm
by WoutTgh
I see, thanks for looking into it. I was thinking along those lines, not enough memory gpu. Would that happen with rendering too much particles ? Strange thing is sometimes it renders competely fine, and other times there's a couple of frames without the denoising, feels very random
Posted: Wed Nov 20, 2019 3:22 pm
by juanjgon
WoutTgh wrote:I see, thanks for looking into it. I was thinking along those lines, not enough memory gpu. Would that happen with rendering too much particles ? Strange thing is sometimes it renders competely fine, and other times there's a couple of frames without the denoising, feels very random
If you have two or more GPUs, select for denoising the GPU with more memory available, only one. You have these settings in the plugin options panel. And never select the display GPU, which usually has less available memory.
Posted: Wed Nov 20, 2019 3:38 pm
by WoutTgh
Yes, I had it set like that already. Non display gpu with 11 Gb ram is set to denoise.
Posted: Wed Nov 20, 2019 3:46 pm
by juanjgon
WoutTgh wrote:Yes, I had it set like that already. Non display gpu with 11 Gb ram is set to denoise.
And if you disable the rendering on this GPU using it only for denoising?
