Page 3 of 12
Re: OctaneRender® for 3ds max® v4.00-RC7 - 6.09 [TEST]
Posted: Mon Oct 29, 2018 5:19 pm
by DartFrog
Hi DartFrog,
I think it depends on texture compression which is very slow, could you try testing with this scene?
https://we.tl/t-hTs1zChs31
I opened up a new max 2018, rendered a teapot, opened up your scene, clicked render, no render. Says "rendering" at the top of the window, but "scene evaluation" never goes away.
Posted: Mon Oct 29, 2018 10:14 pm
by mbetke
I get really random crashes while batch rendering some scenes. The release is not so stable. Scenes which crash, render fine on second try. The scenes always load but 3ds max crashes before render starts.
The scenes are similar products. All scenes are the same except sometimes the product has a wall or other attribute. Materials are the same in all scenes.
I have no idea how to analyze the errors. VRAM and RAM are plenty available.
Posted: Tue Oct 30, 2018 7:49 am
by paride4331
DartFrog wrote:
Hi DartFrog,
Hi DartFrog,
it seems as you have disable tonemap, but I know I say up nonsense.
What's the Octane error log reading?
Posted: Tue Oct 30, 2018 11:13 am
by HHbomb
Hi, I don't know if it is 6.09 specific, but when using a black body on a diffuse material with transpency map, with transparent emission unchecked , surface emission checked and visible on specular unchecked, I get a white edge around the objects.
I render with alpha, and compose it with a black background in PS.
Posted: Tue Oct 30, 2018 12:27 pm
by DartFrog
Hi DartFrog,
YES!
The new version didn't auto-choose a tone-mapping graphics card so it was left unchecked, which makes it not render. Thank you!
Posted: Tue Oct 30, 2018 3:15 pm
by paride4331
HHbomb wrote:Hi, I don't know if it is 6.09 specific, but when using a black body on a diffuse material with transpency map, with transparent emission unchecked , surface emission checked and visible on specular unchecked, I get a white edge around the objects.
Hi HHbomb,
It's quite normal what happens in your render; using diffuse material would not happen. A workaround is to put falloff node in roughness slot.
Posted: Tue Oct 30, 2018 4:46 pm
by HHbomb
Hi, Paride, but I have "visible on specular unchecked" in black body...
Here is the same render with a diffuse material applied to all objects.
Posted: Tue Oct 30, 2018 6:25 pm
by DartFrog
Maybe I missed it, but I searched and couldn't find it - Why is it now black outside of a OctaneRender Viewport region render?
Posted: Tue Oct 30, 2018 7:58 pm
by neonZorglub
DartFrog wrote:Maybe I missed it, but I searched and couldn't find it - Why is it now black outside of a OctaneRender Viewport region render?
Hi DartFrog,
You need to uncheck the 'Use Region as Film Region' in Global Preferences / Viewport, to get the previous behavior back.
There are now 2 types of region rendering, as in Octane Stand Alone.
A more convenient icon will be added soon in the Viewport.
Regards,
Posted: Wed Oct 31, 2018 10:52 am
by paride4331
HHbomb wrote:Hi, Paride, but I have "visible on specular unchecked" in black body...
HI HHbomb,
sorry, I'm probably doing something wrong, caould share your scene (in pm if you want) please?
