Page 3 of 7
Re: PMC Materials Error
Posted: Tue Apr 03, 2018 9:15 am
by Silverwing
MRoz wrote:Hi Ahmet,
Since Release 3.08-RC1.1 I experienced weird things with PMC mode.
All my materials becomes white, lighting works but materials aren't.
I thought it was because my materials were created in an older version but it seems that it's the same with new ones and fresh scene.
Release 3.08test6.1 is working fine for me though.
Thank you,
Maxime
I have to bump up that post vom MRoz since I have experienced the same behaviour.
Old scenes completely ignore Octane Materials when working in PMC mode. The materials just render as diffuse gray.
For me copy / pasting the scene into a fresh C4D File helped.
Maybe there can be done something about it.
Sorry, I don´t have a example scene right now but it should be reproducible with any scene that was created in Octane 3.07 and before.
Tried it with Octane 3.08 RC3 on C4D R19.053
Cheers,
Raphael
Re: Version 3.08-RC3
Posted: Tue Apr 03, 2018 12:56 pm
by frankjrmi
Kretschi wrote:Hello,
Thanks for the new build.
Works fine on Mac Cinema 4D R19...
One strange thing: Textures are rendered differently on front and back normals...
What is your Mac setup? I have a 2013 trashcan with AMD cards and still can't get Octane to run (I have to run it on my Windows machine).
Posted: Tue Apr 03, 2018 1:25 pm
by bepeg4d
Hi frankjrmi,
currently you still need an Nvidia GPU to work with Octane on your Mac,.
Please, have a look at this alternative eGPU solution via Thunderbolt port starting from this discussion on the Otoy forum:
viewtopic.php?f=30&t=62409
In this way, you can use the internal AMD GPU for system/monitor/OpenGL, while the external GPU is used only for CUDA rendering, at full power and with all VRAM.
At the following link you can find an extensive guide about eGPU solutions via Thunderbolt under Mac:
https://egpu.io/setup-guide-external-graphics-card-mac/
ciao Beppe
Posted: Tue Apr 03, 2018 1:52 pm
by niestudio
Cheers,
Raphael
Irradiance mode is ticked by default when opening a 3.07 scene in PMC. When I untick it, the materials come back from grey.
When creating a new scene in 3.08 it's unticked by default
Posted: Tue Apr 03, 2018 2:00 pm
by Kretschi
frankjrmi wrote:Kretschi wrote:Hello,
I have a 12 core MacPro (late 2010) with Nvidia Geforce 980 Ti and processor upgrade...
Posted: Tue Apr 03, 2018 3:26 pm
by aoktar
Nice point. So it should be due wrong default value for the parameter. I'll fix if so. Thanks!
Posted: Tue Apr 03, 2018 3:52 pm
by niestudio
typo in the camera tag custom LUT section
Posted: Tue Apr 03, 2018 10:31 pm
by lucioing
Hi Ahmet!
So, 3.08 is here!
Maybe I'm wrong, but clicking on button (Image texture)
to load a map, I get this:
Instead, as always, this
The same, the others channel...
Thank you
L.
Posted: Wed Apr 04, 2018 12:57 am
by aoktar
stefano-dear wrote:I have tried this release but is very slow on my Mac on C4D R19.053 - CUDA Driver Version: 387.178 - NVIDIA Web driver 378.05.05.25f06
I don't know the why...
And crash frequently:
_BugReport.txt
EDIT
The problem is caused by the "Camera Imager", when it is disabled everything works correctly!
Enabling from camera tag? Octane always have a camera imager effect as you did that or not. I'm not sure why it crashes but log points that a crash on the renderer.
Posted: Wed Apr 04, 2018 5:57 am
by stefano-dear
aoktar wrote:stefano-dear wrote:I have tried this release but is very slow on my Mac on C4D R19.053 - CUDA Driver Version: 387.178 - NVIDIA Web driver 378.05.05.25f06
_BugReport.txt
EDIT
Camera Imager cause only slow movements on Live Viewer, crashes are caused by problems that I don't know...
