Page 3 of 3
Re: "Fixed texture environment material editor preview"
Posted: Wed Jan 25, 2017 7:43 am
by mark0spasic
richardyarlett wrote:Interesting to note that this error only occurs when using the mtl editor in STANDARD mode, not in the SLATE mode. If I switch to SLATE mode, which I don't use, everything seems to work fine.
I also have this problem last working version for me was 4.10, and yes this only occurs in mtl editor in STANDARD mode, not in the SLATE mode. Please fix this. :roll:
Posted: Wed Jan 25, 2017 8:29 pm
by haze
Thank you for the details - I will ask Christophe to investigate this issue today. Several other issues have been fixed since the last release already.
Posted: Wed Jan 25, 2017 10:59 pm
by haze
mark0spasic wrote: I also have this problem last working version for me was 4.10, and yes this only occurs in mtl editor in STANDARD mode, not in the SLATE mode. Please fix this. :roll:
Both Christophe and I can't reproduce the issue - so that we can eliminate any other variables, would you be able to provide a minimal max scene that causes this issue? (pls save as archive) thank you
Posted: Wed Jan 25, 2017 11:44 pm
by richardyarlett
Ok, but that is weird. It is literally ANY scene I have. I will do one now. Did you watch the video ?
Posted: Wed Jan 25, 2017 11:50 pm
by richardyarlett
Here you go. It is literally a teapot with a texture environment. If I try to drag that TEXTURE ENVIRONMENT into my MTL EDITOR, the whole session freezes.
https://www.dropbox.com/s/02zzlh111dzqwd8/test.zip?dl=0
Posted: Thu Jan 26, 2017 2:16 am
by haze
Thanks for that - Christophe has had no luck reproducing it on his PC with the scene you sent - if you get a chance, would you mind trying to disable any other plugins you have? I'm still experimenting trying to reproduce it on another machine too.
What version of Windows are you running? (all up to date?)
Posted: Thu Jan 26, 2017 6:33 pm
by richardyarlett
Weird. It happens on all four of my computers, different hardware configs. Same Windows 10 up to date. 3dsmax 2017 up to date. I will try disabling plugins and see
Posted: Thu Jan 26, 2017 6:34 pm
by richardyarlett
How do I disable all other plugins quickly and temporarily ?
Posted: Thu Jan 26, 2017 7:00 pm
by haze
Sorry it seems like it's not as convenient as in Maya, I will PM you.
https://knowledge.autodesk.com/support/ ... ugins.html
