Page 3 of 4
Re: Octane with Skylake CPUs?
Posted: Tue Jan 19, 2016 11:00 pm
by face_off
Have you every been able to render without these Cuda errors? If so, what did you change that then resulted in the errors occurring?
Posted: Tue Jan 19, 2016 11:32 pm
by Scott762
face_off wrote:Have you every been able to render without these Cuda errors? If so, what did you change that then resulted in the errors occurring?
I looked through my renders to get a rough timeline.
I have used Octane Render for Poser 2014 with the two Titan X's for at least 6 months on Windows 7.
I upgraded to Windows 10 Pro x64 sometime Aug. or Sept. I used it up through Oct. 17 without the problems. Then with the holidays I didn't use Poser or Octane until after Christmas, where I noticed all the problems.
Currently I'm on the latest hotfix Nvidia GeForce 361.60 driver hoping that would help (it didn't).
Please help, it's worse. It's intermittent like I thought at first, it's totally unusable.
Posted: Wed Jan 20, 2016 2:59 am
by prehabitat
This isn't related to that windows 10 update affecting sketchup users is it?
Since it occurred from a set time onwards I'd be uninstalling windows 10 updates in reverse order until you get to the date it last worked (or try system restore locations if you use them.. I don't know much about them).
Posted: Wed Jan 20, 2016 4:27 am
by Scott762
Unfortunately I may be stuck at a fairly recent point - I downloaded the offline installer to a USB stick not too long ago, so a bunch of updates are already slipstreamed into it.
Posted: Wed Jan 20, 2016 4:44 am
by face_off
As per my PM to you, I suggest rolling back to Nvidia driver 353.62 and seeing if there problem still occurs.
Posted: Wed Jan 20, 2016 1:53 pm
by Scott762
It's an issue with the drivers!!!
I uninstalled all the Nvidia drivers (HD audio, etc), and it works. I'm using the driver that was included with Windows 10.
If the file isn't visible, it's Driver Version 10.18.13.5362 dated 7/22/2015.
Posted: Wed Jan 20, 2016 5:34 pm
by Scott762
The issue probably started with driver version 358.91 (Nov. 9) or 359.00 (Nov 19).
I got Battlefront on Nov 10th and updated to those driver versions immediately as they came out.
Posted: Wed Jan 20, 2016 6:44 pm
by wimvdb
Yes, the latest NVidia drivers have issues, not only with Octane, but with Poser as well
Also one of the updates of Windows 10 (major 1511 update) cleaned the registry entries for TDR_Delay causing issues as well. Easy fix here is the install the standalone Octane since that sets the registry entry back
Posted: Wed Jan 20, 2016 8:15 pm
by Scott762
wimvdb wrote:Yes, the latest NVidia drivers have issues, not only with Octane, but with Poser as well
I've already installed Octane standalone, and after the Nvidia drivers as well.
Posted: Wed Jan 20, 2016 10:11 pm
by Scott762
In case it isn't obvious, driver version 10.18.13.5362 dated 7/22/2015 is GeForce driver version 353.62.
Can't play Battlefront with that driver. Trying 358.50, minimum for that dated Oct. 7.
