Page 3 of 41
				Re: Version 2.24.2-TEST1 (08.10.2015) - Testing only
				Posted: Fri Oct 09, 2015 10:46 am
				by JavierVerdugo
				Excuse my ignorance, but where is the 2.24.2 standalone release? I can't find it.
At the moment I can't install the plugin, remove the last one (2.24.0) when I install the new one It says plugin not found.
				Posted: Fri Oct 09, 2015 10:54 am
				by JavierVerdugo
				Aoktar maybe this is important.
I tried to install the plugin on cinema 4d 17. I downloaded the zip file, erase all the cdl64 except the R17 and the plugin didnt work. This time I erase all except R16 and the plugin works. Something wrong happens with c4dOctane-R17.cdl64 file.
				Posted: Fri Oct 09, 2015 11:10 am
				by aoktar
				JavierVerdugo wrote:Aoktar maybe this is important.
Thanks for info. What's build/version numbers of R17?
				Posted: Fri Oct 09, 2015 11:20 am
				by aoktar
				fatfreemedia wrote:Thanks - this update is great. Is there any way to shade the particles via Octane or is that in a future release?
You can use custom objects via object tag. I'll remove "particle engine" option from LV menus. Thanks.
				Posted: Fri Oct 09, 2015 11:21 am
				by aoktar
				ron908 wrote:Looking forward to the R17 release - can you make sure, that the Token system will be supported in the Render Passes filename fields? It's rather important, because otherwise the passes just overwrite each other...
I haven't tested it honestly. Because haven't time to do. We'll see...
				Posted: Fri Oct 09, 2015 11:37 am
				by krzychuc4d
				Hi Aoktar,
any chance to add possibility to change GPU priority when rendering to picture viewer ?
I mean on the fly, after i start rendering to picture viewer
				Posted: Fri Oct 09, 2015 11:54 am
				by b1siu
				Also, for me, this option is very important. Please respond because it depends on us over time.
				Posted: Fri Oct 09, 2015 11:56 am
				by aoktar
				krzychuc4d wrote:Hi Aoktar,
Why do you wish that? Settings window is disabled on anim. rendering to avoid problems.So this requires new interface for Render Settings.
				Posted: Fri Oct 09, 2015 12:23 pm
				by krzychuc4d
				aoktar wrote:krzychuc4d wrote:Hi Aoktar,
for example:
1.
When rendering long animation I want to use full speed
but sometimes I need to do some other task in back ground.
Because of that I have to stop rendering (octane eat whole GPU power)
when i hit render again cinema calculates whole project/dynamic sim (even if it's baked)
as you know precalculation takes sometimes 10-20 min (complex projects)
2.
same with very high resolution stills in picture viewer.
If project needs couple hours to complete and we wish to do something in background...
If we could change GPU priority PViewer  on the fly we can save time.
But if its impossible or take to much time that is fine, don't worry
				Posted: Fri Oct 09, 2015 1:06 pm
				by Weezer
				Hi – where is the new Scatter Object? Not seeing it on OS X version. Thanks!
Also, Displacement seems to be broken with this release – not getting anything happening.
