Page 3 of 9
Re: Version 2.20.0 RC1 - Release candicate 1
Posted: Tue Jan 27, 2015 8:27 pm
by desire
inlifethrill wrote:
These are quick buttons that allow you to preview enabled render passes (Octane Settings)...
One thing about these buttons. They disappears after render stops. For example, I use LV for quick tune materials etc etc... Quick, fast, not detailed. Big size render in future. And I set small numbers of samples for that, naturally.
I get picture in seconds, render stops, and it's no possible to preview rendered passes without restarting render progress..
I don't know about other users, but sometimes I have a little demons inside for disappearing buttons
Posted: Tue Jan 27, 2015 9:40 pm
by inlifethrill
You can force the buttons and render statistics stay on screen by going to Octane Settings -> Settings -> Other -> Enable "Keep Stats". Hope this helps.
Cheers!
Posted: Wed Jan 28, 2015 7:15 am
by desire
inlifethrill wrote:You can force the buttons and render statistics stay on screen by going to Octane Settings -> Settings -> Other -> Enable "Keep Stats". Hope this helps.
Cheers!
Oh, your knowledge has no bounds. Cheers!
Posted: Thu Jan 29, 2015 8:50 am
by tomabobu
The background object doesn't seem to work (R16).
If I open "background_and_matte.c4d" scene from the sample scenes, the background object works like it supposed to, but if I try to recreate the setup in another scene it doesn't. Further more, if I merge a new scene with the sample scene it doesn't work.
Is there another solution for setting up a background image (other than in compositing)?
Posted: Thu Jan 29, 2015 8:51 am
by LSDI
Hi Aoktar
I installed the rc 2.20 on c4d r13, livewer operates normally, but after running "render to picture viewer", and stop it, i can't launch liveviewer, i need to stop and restart c4d.
Do you know this pb?
Pascal
cinema 4d 13
3 gtx titan black
3 gtx titan
Posted: Thu Jan 29, 2015 9:28 am
by aoktar
tomabobu wrote:The background object doesn't seem to work (R16).
is alpha enabled in kernel settings?
Posted: Thu Jan 29, 2015 9:35 am
by tomabobu
I've noticed that the "Surface Brightness" and "Cast illumination" parameters are working on the "Blackbody Emission" node but not on the "Texture Emission" (R16).
Is there a difference between the two of them if you don't want emitted light?
Thank you.
Posted: Thu Jan 29, 2015 9:39 am
by aoktar
LSDI wrote:Hi Aoktar
Pascal
cinema 4d 13
3 gtx titan black
3 gtx titan
can't see same behaviour. Can you check it for a different scene to see same again?
Posted: Thu Jan 29, 2015 9:40 am
by aoktar
tomabobu wrote:I've noticed that the "Surface Brightness" and "Cast illumination" parameters are working on the "Blackbody Emission" node but not on the "Texture Emission" (R16).
Thank you.
Both are new parameters and honestly i have no idea about this questions.
Posted: Thu Jan 29, 2015 9:43 am
by tomabobu
aoktar wrote:tomabobu wrote:The background object doesn't seem to work (R16).
Damn! It wasn't.
Thank you very much for your help and for your patience.
