Re: OcDS 2.1 PRE RELEASE 2nd
Posted: Wed Nov 05, 2014 7:17 am
When will the Daz plugin have HdrLight Studio plugin Capability?
Community Forums for OTOY Customers
https://render.otoy.com/forum/
Yep, that did the trick. Many thanks, t_3 (and rajib). Wow, lots of new features to play with!t_3 wrote:pls let me know if this helped...
great. i'm going to use an older packager version for the next setup file; in theory the latest version should have had some fixes esp. for win8.1, but hey, i'm the last one to raise his voice about fixes that didn't fixAtticusBones wrote:Yep, that did the trick. Many thanks, t_3 (and rajib). Wow, lots of new features to play with!t_3 wrote:pls let me know if this helped...
Only issue i've noticed so far is that materials seem to load automatically regardless of the box being unchecked.
Also, what joelgecko said: "NOT A BUG but I haven't found where to load a sky texture map in the daylight settings..."
rajib wrote:If you are on Windows 8.1, just right click and select "Troubleshoot Compatibility". Then select "Try recommended settings". The installation completes successfully. I was getting a crash with the installation package. This is how I managed to run it.
painterhoya wrote:unpack error..... it's a not working install
Can't connect node 'RGB Image' (NT_TEX_IMAGE, 0000000030F6A060) to static pin 'diffuse' (P_DIFFUSE, type PT_TEXTURE) of node 'Diffuse Material' (NT_MAT_DIFFUSE, 0000000030F45EA0)
