Page 3 of 73
Re: OctaneRender for Modo (Windows) 2.11.1 [TEST]
Posted: Tue Oct 21, 2014 2:55 pm
by v1adut
Modo Features Request
Hi Paul,
Here is the issue,
Modo has a nice way to save assemblies for later use, for example:
A character textured, rigged, can be then used with a double click into an new scene.
I tried this with a character that has octane material applied, but when imported the links get messed all up, and the material does not
come with the mesh, even when I check in the groups editor, the group related to the mesh contains all the elements needed for that object, like locators, octane nodes, but the links are broken.
My request, can you please take a look into this issue and see if the links can be perpetuated in the new scene for later use ?
Cheers,
Vlad
Posted: Tue Oct 21, 2014 3:05 pm
by v1adut
I think if this is fixed, we can make material presets for modo, and this will be a huge workflow kick for me.
Posted: Tue Oct 21, 2014 9:10 pm
by face_off
Could you pls send me the rigged character with the Modo materials?
You can already create a preset for a single Octane material ("Save as Preset" button).
Posted: Wed Oct 22, 2014 12:16 pm
by Obizzz
I get this error when starting Modo. I guess it's looking for something that's not there. Is there a way to fix this?
Started logging on 22.10.14 14:12:44
OctaneRender version 2.11.1 (2110002)
Failed to load preferences from "C:\Users\Martin\AppData\Roaming\OctaneRender\{84d9621349fa4b4fb8ee78d63c54d977}\preferences_v2"
Posted: Wed Oct 22, 2014 1:34 pm
by face_off
You should only get this the first time you start Modo after updating to the latest release. The warning should not appear on subsequent Modo sessions.
Posted: Wed Oct 22, 2014 3:23 pm
by Obizzz
face_off wrote:Failed to load preferences from "C:\Users\Martin\AppData\Roaming\OctaneRender\{84d9621349fa4b4fb8ee78d63c54d977}\preferences_v2"
Haha, I had an error popping up everytime I started Modo before. I just updated to the latest version and it was still there. Turns out it was just this first time thing so my original error is gone
Posted: Sun Oct 26, 2014 2:39 am
by face_off
I have refreshed the installer at the top of this thread with:
2.11.1.34
- Fixed projection mapping issue with Planar mapping in the X and Z axis
- Fixed a number of issues resulting in incorrect frame numbers being displayed when rendering animations
2.11.1.33
- Fixed issue where saving as Multi-layer EXR in animations was saving the frame prior to all passes finishing rendering
- Added the Render Pass name currently being rendered to the Render Statistics
Posted: Sun Oct 26, 2014 5:18 am
by funk
face_off wrote:Added the Render Pass name currently being rendered to the Render Statistics
Paul, this isnt working correctly. It's always showing the last pass name from all the passes you are rendering. Msamples per second always shows 0.00 too.
Posted: Sun Oct 26, 2014 10:43 pm
by face_off
Fixed in the next release.
Posted: Mon Oct 27, 2014 2:44 am
by face_off
Hi Vlad - thanks for sending through the scene and additional info. Answering here in case others have the same question....
If you have a rigged character/figure, if you rightclick the Item and "Save Assembly", it will save the figure as an Assembly - but because each Octane Override for that figure is it's own Assembly, when you reload the saved Assembly, all the Octane Overrides will be in the one Assembly - and not work correctly.
Instead you need to save the figure as a Preset (although in the specific example you sent me, you need to merge the balls with the clown, or save the clown and balls as separate Presets).
