Page 3 of 10
Re: Octane for Softimage 1.02 RC12 [Current]
Posted: Fri Oct 24, 2014 9:57 pm
by nuverian
Hello face,
I've installed the addon prior to activating my standalone license after a new pc format.
The XSI account verification showed up once where entering my account details failed (possibly due to no having the standalone licence installed prior)
I then installed Octane standalone license and tried Softimage again, but I get the account verification no more.
If I open "OctanceRender>RenderSettings", console says invalid as it should, but the ppg opening is just..empty. An empty ppg.
So right now I really don't know what I must do to activate my license.
I tried uninstalling > installing the addon but to no avail
Any help is appreciated
Posted: Sat Oct 25, 2014 8:04 pm
by face
nuverian wrote:Hello face,
Have you tried to update the render properties? There is a menu entry for this.
It´s also possible that there is a "octane_live_account.cfg" in the plugin directory which should be deleted as a test.
face
Posted: Mon Oct 27, 2014 7:42 am
by nuverian
face wrote:nuverian wrote:Hello face,
face
Hello again,
Update Render Properties does nothing at all right now (no console log either).
There is no "octane_live_account.cfg" in the plugin directory created at all. Could that be the issue?
By the way, I am also deleting the whole plugin directory after uninstalling the addon before reinstalling
Posted: Mon Oct 27, 2014 11:06 am
by face
nuverian wrote:
Hello again,
On a blank installed plugin, there shouldn´t be a "octane_live_account.cfg" file, that is correct.
Which Softimage version you use?
face
Posted: Mon Oct 27, 2014 2:54 pm
by nuverian
face
Hello,
I am using version 2015.
Thanks for helping out
Posted: Tue Oct 28, 2014 1:41 pm
by face
Strange, have you installed the Microsoft Visual C++ 2010 Redistributable?
face
Posted: Thu Oct 30, 2014 1:46 pm
by fati_r
hello face,
I've just hade time to try the RC12 release, and unfortunately it is not working, actually what happens is that by clicking on preview button the SI is exporting the geometry but then the preview window stays blank like it has stopped and nothing happens further! had to reverse to RC11 and everything works properly! any idea what is causing that problem?
and another question wich is not related to that problem, awhile ago you hat an exporter that would writte an .obj file that we could use with Octane standalone, is it maybe possible to get that functionality again?
thanks
fati
Posted: Fri Oct 31, 2014 7:02 am
by face
fati_r wrote:hello face,
Also SI2015?
Try to reopen the preview window.
thanks
fati
I can only export the current scene which is in the gpu. This scenefile can be used in the standalone.
face
Posted: Fri Oct 31, 2014 1:34 pm
by nuverian
face wrote:Strange, have you installed the Microsoft Visual C++ 2010 Redistributable?
face
I retried opening the "Render Settings" now and it opens correctly (no empty). I can't really tell what made it to work. But one thing that "I think" has changed is that I installed latest nvidia driver. You see the moment I tried and posted before, it was after a very newly formated system. So I suspect that with the dirvers I had previously there was no CUDA support and it COULD be the issue, but again, I am not sure.
So I was able to activate my account now.
Problem is that like the other user here, the Preview window is empty. The progress bar (samples per pixel) also doesn't move.
Of course I tried reopening the window, scrubing the time (don't know if that's still relevant). C++ redistributable is installed.
RC 11 works fine though. One slight thing that I noticed (maybe it's totaly irelevant), is that in the "OctaneLive Account" tab at the botton, the ID in RC 12 is not shown where it does in RC 11 (with an activated account)
Posted: Fri Oct 31, 2014 4:37 pm
by fati_r
thanks for reply face,
unfortunately even when I restart the preview window the rendering doesn't start, I tryed everything... it of course opens the window and I get all the information on the status bar, and it stays at "0/16000s/px..." and I doesn't do anything else further...
as for the exporting what's in the GPU, how do I do that? or is it not implemented yet?
thanks again.
ps. back to RC11 cause it works for me
