Page 3 of 3
Re: Octane for Softimage 1.02 RC11 [Current]
Posted: Sat Aug 16, 2014 7:03 am
by face
ivom wrote:When I select exr as the render output file it seems it's png file with exr extension.
Can you check that please.
Thank you
AD
It looks youre right, have forgotten to set some brackets.
The exr output file was overwritten from a 16bit png file.
Also solved.
face
Posted: Sat Aug 16, 2014 5:04 pm
by abeoctane
Hi face, if possible, can you please include too in RC12, the fix for the autofitviewer option, that when activated the render freezes at "set gpu", thank you very much.
Posted: Mon Aug 18, 2014 5:11 am
by face
abeoctane wrote:Hi face, if possible, can you please include too in RC12, the fix for the autofitviewer option, that when activated the render freezes at "set gpu", thank you very much.
I can try it.
face
Posted: Mon Aug 18, 2014 3:11 pm
by tullioz
Hi face,
I own Softimage 2012 SP1 and Octane 1.02 RC11. My blackbody emission node apparently does not have an output pin.
With Octane 1.02 RC4 the output pin is visible.
So I think that there is a compatibility issue. Could you please confirm that?
Posted: Tue Aug 19, 2014 6:03 pm
by face
tullioz wrote:Hi face,
There was only an issue in the shader source which is solved in the next version.
face
Posted: Wed Aug 27, 2014 5:46 am
by face
Sorry for the delay, but i need more time to bring out the next RC.
I restructure the most parts of the plugin under the hood.
This will make thinks easier to implement and i hope that some other problems will also be fixed.
face
Posted: Thu Aug 28, 2014 4:22 am
by abeoctane
Thanks face for your hard work,
Softimage 1.02 RC11: Severe installation problems
Posted: Sun Aug 31, 2014 7:28 pm
by peegeedee
I tried to update from the old 1.01 Version to this new one:
First I deinstalled the old plugins.
Then I installed this addon with the help of the manual.
Now I can't enter the username and PWD, because the Render Settings do not open.
Instead I get following message:
Application.SetValue("Passes.Default_Pass.Renderer", "Octane Renderer", "")
# INFO : Initialize OctaneRender® for Autodesk® Softimage® 1.0211 RC11
# ERROR : Invalid OctaneLive plugin account or wrong liveId / password combination.
Have Softimage 2014 SP2, Windows 7 x64
Thanks for any help!
Posted: Sun Aug 31, 2014 9:08 pm
by face
peegeedee wrote:I tried to update from the old 1.01 Version to this new one:
Try to delete the octane_live_account.cfg in the plugin directory.
Hope it solved it.
face
Posted: Mon Sep 01, 2014 6:16 pm
by peegeedee
This octane_live_account.cfg file just didn't exist.
It was my fault, I hadn't the latest driver installed for my Quadro K4000M.
Now have installed the 377.88 driver and everything is working properly.
Thank you!
