Page 3 of 5
Re: OctaneRender® for 3ds max® v2.01
Posted: Fri Jun 27, 2014 9:39 pm
by oguzbir
j7th wrote:nildoe wrote:Karba this version Breaks Hairfarm...Hairs are not rendering anymore...what do i need to do? is it a bug?
Nildo
Same problem with Ornatrix.
ME too.. No hair with ornatrix.
Posted: Fri Jun 27, 2014 9:44 pm
by acc24ex
REGION RENDER NOT SHOWING/WORKING WHEN RESOLUTION LOCK ACTIVATED
LIVE DB TEXTURES PATH NOT SAVING IN FOLDERS WITH SPACES
(again)
Posted: Sat Jun 28, 2014 11:47 am
by mykola1985
Hi Karba,
it would be nice to see the ''low priority'' button in the octane render viewport. i think it would be more comfortable when you are in full screen mode especially for those having a single monitor
Posted: Sat Jun 28, 2014 1:03 pm
by mikinik
in this version on old scene max2015 shows error after press render button. if I open octanerender viewport, 3ds max crashes.
Posted: Sat Jun 28, 2014 1:32 pm
by avidia64
mikinik +1
Posted: Sat Jun 28, 2014 3:56 pm
by mark0spasic
mikinik wrote:in this version on old scene max2015 shows error after press render button. if I open octanerender viewport, 3ds max crashes.
the same
Posted: Sat Jun 28, 2014 11:18 pm
by visionmaster2
Same for me.
Posted: Sun Jun 29, 2014 2:57 am
by emihich
I am having the same issues with Max 2014 and 2015, for me Octane viewport don't open in Max 2014, and trying to render gives me an error that crashes Max.
Posted: Sun Jun 29, 2014 7:48 am
by gabrielefx
I confirm the opacity issue with greyscale maps, it's ok with the rgb ones.
I encountered an error after having rendered with rendering network enabled:
I isolated one 3d object, pressed reload, the frame buffer visualized only the gradient square image.
I have had to restart Max.
Please delete or hide from the fb that square image and the default camera position (first seconds of render)
regards
Posted: Sun Jun 29, 2014 9:22 am
by mykola1985
i get this in error log when viewport doesn't start:
Started logging on 29.06.14 10:03:56
OctaneRender version 2.01 (2010000)
can't set empty array as animation. use clearAnim() to clear an animation.
