Page 3 of 3
Re: Render skipping frames issue
Posted: Sat Sep 26, 2015 9:10 pm
by aoktar
CCIDgfx wrote:Here are the log files for the most recent skipping issue
Better now. Skipping occured after 806? Do you see <<RenderFailure>> in lines?
Posted: Sat Sep 26, 2015 9:18 pm
by CCIDgfx
I started the render at frame 802. Making corrections to the video.
Posted: Sat Sep 26, 2015 9:20 pm
by aoktar
CCIDgfx wrote:I started the render at frame 802. Making corrections to the video.
Can you confirm that as yes or no? I can't understand what you mean!
Posted: Sat Sep 26, 2015 9:26 pm
by CCIDgfx
The logs I sent were from a short render that i started at frame 802. So the failure happened after 4 frames. I just made it through the 44 frame render with no issues but that was after having to restart the render due to the skipping. This happens no mater the amount of frames. I usually have to restart the render on or 2 times before it stops skipping frames.
Posted: Sat Sep 26, 2015 9:32 pm
by aoktar
CCIDgfx wrote:The logs I sent were from a short render that i started at frame 802. So the failure happened after 4 frames. I just made it through the 44 frame render with no issues but that was after having to restart the render due to the skipping. This happens no mater the amount of frames. I usually have to restart the render on or 2 times before it stops skipping frames.
Following lines from your log output. Do you know what's the meaning of CUDA error? It shows that an error occured in renderer(Cuda codes) by a reason. I don't know the reason. Maybe unsuffient vram, lot of triangles, driver or gpu hardware errors, etc.. So plugin can't render the frames and skipping occured.
FRAME 803 fps:30 movable:84 camMb:0 objMb:0
FRAME 804 fps:30 movable:84 camMb:0 objMb:0
FRAME 805 fps:30 movable:84 camMb:0 objMb:0
FRAME 806 fps:30 movable:84 camMb:0 objMb:0
CUDA error 700 on device 2: Error code unknown.
-> kernel execution failed (pt)
device 2: path tracing failed
<<< Render Failure >>>
-> failed to deallocate device memory
-> could not get memory info
