Page 3 of 5
Re: OctaneRender® for Poser beta - build 1.02s [TEST]
Posted: Sun Mar 03, 2013 8:59 pm
by ch0pper
Think I found a possible bug today whilst rendering. If you minimise the render, window and then
come back to it may be a few minutes later. It will reset the render can back to 0 and your render
was start from scratch again . I lost five hours of rendering time today because of it.
You're fine. If you leave the window as it is rendering full-size. But if you minimise it. This is where the bug seems to to start.
I have two graphics cards gts 450 and gtx 6600TI , the GTX does the main work and the 450 just sits in the background so I can do other things
Posted: Sun Mar 03, 2013 9:50 pm
by face_off
I will check this out. In the meantime, I suggest a) use progressive save - it's designed to save you from this situation, and b) you can activate the "No Updates" button, and that will lock out any changes that might restart the render.
EDIT: I wonder if you accidentally clicked on the Viewport after it restored, caused the focus pick to change the focus? I am changing how this works in the next version, and there will be a Focus Pick button you need to click first to pick the focus. And there are some other features to be built in....
EDIT2: The render is restarting for me too when I restore the viewport. I will fix this in the next day or so.
Posted: Mon Mar 04, 2013 8:44 am
by face_off
Earlier today I updated the 1.02s installer to fix the render restarting issue when restoring a minimised window. I also fixed a couple of other minor issues relating to closing a minimised window (was restoring to a different size), and activating/deactivating resolution locking.
Please re-download and install the installer from the link at the top of this thread.
Posted: Mon Mar 04, 2013 12:28 pm
by Ken1171
Hi Paul,
I am having an issue with the plugin "forgetting" my license registration every time I run a Windows files clean-up. This happens because the plugin stores log data at a temporary Windows folder that gets wiped out. I came to this conclusion based on the error message I get (see below):
An errror occurred importing addon OctaneRender for Poser :
ERROR: [Errno 2] No such file or directory: u'C:\\Users\\Ken\\AppData\\Local\\Temp\\Poser Pro\\9\\octaneplugin.log'
When I checked it out, the "user/AppData/Local/Temp" folder always gets included in Windows' files clean-up sessions, and whenever this log file gets deleted, my Octane license goes away with it. Maybe it would be a good idea to store data in a less volatile location?
Posted: Mon Mar 04, 2013 9:22 pm
by face_off
Hi Ken - very good point. I will change this to the Poser "Preferences" folder. The default location for exported materials, and the LiveDB texturemap cache probably need to change too. I will need to release this as 1.02r, since it is such a major change, people will need to understand the specifics of the change.
Posted: Mon Mar 04, 2013 11:23 pm
by Ken1171
face_off wrote:Hi Ken - very good point. I will change this to the Poser "Preferences" folder. The default location for exported materials, and the LiveDB texturemap cache probably need to change too. I will need to release this as 1.02r, since it is such a major change, people will need to understand the specifics of the change.
I understand LiveDB is storing materials used by scenes at a local folder? Is there an option to keep ALL the LiveDB materials local, so we don't have to wait until it downloads them when editing materials? Even though I have cable broadband, I noticed the mouse-over previews still get sluggish because they have to access the materials remotely. I would prefer to access them locally for the sake of performance. How large is this package?
BTW, wouldn't the next version be 1.02t?
Posted: Mon Mar 04, 2013 11:38 pm
by face_off
When you mouse-over, it loads the preview into memory, and then if you re-mouse-over, it pulls the preview from memory. There is no easy way to download all the LiveDB to your PC, since a) if would take too long, and b) it wouldn't be Live :-) In theory the plugin could be enhanced to download each LiveDB material into Poser plugin import/export format, but you would need to download the whole liveDB regularly, and it would take a long time. I have noticed the LiveDB performance has improved dramatically in the past month (potentially due to Otoy increasing bandwidth).
Also, if you load a LiveDB material in the Poser plugin, then export it (or save the Poser scene), the Octane nodes will be referencing the texturemaps in the LiveDB download cache area - so it is important these are not deleted, so that's why they need to go into the Preferences area rather than the current Temp folder.
Yes - my error. In fact, hopefully 1.11t.
Re: OctaneRender® for Poser beta - build 1.02s [CURRENT]
Posted: Thu Mar 07, 2013 3:14 am
by face_off
New version is up - pls see [url]render.otoy.com/forum/viewtopic.php?f=45&t=29153&p=127404[/url].
Posted: Mon Mar 11, 2013 4:47 pm
by Ken1171
I love the ability to copy a shader change to all SKIN materials, but it becomes a nuisance when it also overwrites the LIP material, which is not skin and uses a different shader. Would it be possible to remove the LIP material from what is considered "skin" in the Octane plugin? I would greatly appreciate that! ^____^
Also, whenever I run out of texture map slots (CUDA limitation), is there an easier way to find where the specific grayscale maps are? The plugin complains when it happens, but doesn't help me locate where they are, so I can decide which ones have to go...
Posted: Mon Mar 11, 2013 5:11 pm
by wimvdb
I think you can remove the lips in the plugin configuration file (remove it from the list). It is usually the same textures are used and often it is just a small adaptation (if at all). So removing it from the plugin would not be a good idea for everyone
The Scene Texture Counter script in the Octane plugin scripts for Poser tells you where and which bump maps are used. That is a good start
Other thing you have to watch out for is "double" use of textures. If the same map is connected to the diffuse and the bump map channels, two maps are created: Image and Float_Image. Copy the Image node into the Float_Image node and you save a slot (you have to do that for all references before it becomes free)
