Here is an update from me:
Installed a GTX 460 in my macPro(2008-3.1)
I already have an 8800GT so here are the steps that I took to do this:
1. Buy
Molex y splitter,
molex to 6 pin adapter,
pci express power extension cable(2),
mac pci express power cable, and...the graphics card
2. Update snow leopard software and boot into osx. Shut down and let the machine cool off.
3. Refer to this
guide and remove:
- Slide out all hard drives
- Pop off heat sink cover
- Remove fan assembly
- Remove current GPU
- Remove Optical drive cage
4. At the optical drive, you will see a singe molex power cable available - connect the y splitter cable.
5. Connect the molex to pcie power cable to the end of the Y splitter cable.
6. Guide the connected cables down to the fan assembly area.
7. Connect the pcie power extension cables.
8. Snap back the optical drive cage.
9. Put the fan assembly back [Note: it is important that the pcie power extension cable goes under the fan assembly and not above it or the cable will be in the way of one of your hard drive slots.
10. Pop back the heat sink cover.
11. Put in the original GPU.
12. Put in the new GPU in the slot above the original GPU.
13. Connect the newly inserted pcie power extension cable to the new GPU's second pcie power connector
14. Connect the mac pcie power cable to the new GPU's first pcie power connector and connect the other end at the last available motherboard pcie power connector.
15. Slide the hard drives back.
16. Put the cover back on and enjoy the added render power in Octane Render (in Windows 7 64). The whole point for me was to not pay $500 for a GTX 285 Mac edition, when I can get a 2GB GTX 460 for $250 - less money & more power
Note: The reason I say to update osX before adding the card is that everything was working for me UNTIL I updated OSX after the install. Upon reboot OSX would hang on log in (blue screen). As I type this in OSX, I removed the card and logged in. I will report back if there was in fact something in the update that screwed up the ability to have a non Apple supported card in or if it was just during OSX update and reboot that the card could not be present (I am really hoping for the latter).
