Page 20 of 20
Re: Version 2.24.1-R3 (06.10.2015) - latest stable
Posted: Sat Oct 17, 2015 7:25 pm
by indexofrefraction
sent you a PM
and... thanks being here even on weekends for people's troubles! :)
Posted: Wed Oct 21, 2015 2:56 pm
by MoGrafik
Not sure if it's come up already...Just reporting a problem I've just run into. I've got a pretty basic scene,but it crashes when I try to render with motion blur on? I had been using the 2.24.2 test, so I went back to this stable one, and it still does it.
Any suggestions?
Posted: Wed Oct 21, 2015 3:35 pm
by aoktar
MoGrafik wrote:Hi,
Any suggestions?
SUGGESTION: Please read how to post bugreports. It's on first page. Thanks.
Posted: Mon Nov 02, 2015 3:42 pm
by mentor972
Just a note on the CUDA driver for Mac. We did have 6.5 or higher, but the engine would not do anything. Our theory is because of our simultaneous El Capitan upgrade. Once we upgraded to the newest 7.* Cuda Mac driver everything worked. So, basically somewhere between 6.5 and 7.* the CUDA driver will not work with this version on El Capitan. As long as you use the newest CUDA version it should fix your problem. (10/1/15 CUDA Update is what we upgraded to.)
Posted: Wed Nov 04, 2015 10:19 am
by fuchsundvogel
as i am a little confused where to post bugreports i mention it here aswell:
viewtopic.php?f=86&t=51036&p=254026
when i render with commandline and use the camera imager the render is darker
Posted: Fri Nov 06, 2015 11:19 am
by Equinoz
since 2.24.1 R1 the xparticles can't display on live viewer. I have enable the particle engine but it still not working
Posted: Sun Nov 08, 2015 9:55 pm
by chouki
As said above ^^ about X-Particles :
With this version 2.24.1 the only way to see X-Particles in Live Viewer is to put a generator in X-Particles.
Example: you create an X-Particles setup, and asign an Octane material to the emitter. In version 2.24.0 it worked, particles were rendered by Octane. Not with this one, unless you generate geometry from XP, wich can become very heavy in polygons.
So I'm back to 2.24.0, too bad, I originally switched to 2.24.1 because of the crash when putting a material in the Local DB.
Posted: Sun Nov 08, 2015 10:33 pm
by aoktar
chouki wrote:As said above ^^ about X-Particles :
I'm not working on this version. I'm trying to make a stable version from 2.42.2 TEST version. It has all features you say.
Posted: Sun Nov 08, 2015 10:38 pm
by chouki
Great to hear that. I have no doubt you guys are working hard to make everything stable! cheers
