Page 15 of 32
Re: OctaneRender™ for LightWave™ 2.0 DAILY BUILD
Posted: Thu Aug 07, 2014 3:09 pm
by juanjgon
MrFurious wrote:With InfoChannel could AO distance please be added to the next release, at this time it's more or less useless and everything is very dark. I think it's set to infinite distribution distance by default with no way to change it.
Cheers
Done ;) ... thanks for report this missing parameter.
Posted: Fri Aug 08, 2014 12:30 am
by MrFurious
Cheers
Awesome.. also a couple other parameters missing:
-Ray Epsilon (no idea what this does though)
-Wireframe Backface Highlighting
Cheers, Dino
Posted: Fri Aug 08, 2014 7:40 am
by juanjgon
MrFurious wrote: Awesome.. also a couple other parameters missing:
Cheers, Dino
Wireframe Backface Highlighting is the parameter "Highlight backfaces", but I should add the ray epsilon parameter.
Posted: Sun Aug 10, 2014 8:37 pm
by FrankPooleFloating
:cry: Oh crap. It happened again... I opened an older LW project, converted everything to Octane.. got a fair amount into it.. was having difficulty getting things the way I like them... had some real nastiness in the shadow areas..............
And then realized about an hour into this fiasco that I had (once again) not switch to Full Linear CS workflow at beginning.... :cry:
Juanjo pal, is there any way you could implement an automatic switch to Full Linear, whenever we "Switch to Octane"?... I think this has been asked before, but I can't remember if this was possible for you....
Posted: Sun Aug 10, 2014 9:43 pm
by alexos
Ah, so I'm not the only one suffering from CS nastiness. Apart from old scenes, I still use the native LW engine from time to time and forgetting to re-set everything to linear can lead to some truly painful hours of wasted work. Seriously, just a pop-up window or something that says "Remember to switch colorspaces, you dolt!" upon Octane activation would be enough for me!
ADP.
Posted: Mon Aug 11, 2014 4:52 am
by geo_n
If you guys are working with linear workflow in octane, how do you degamma textures?
In kray its recommended to put lw in linear then use kray's own linear plugin to degamma textures, etc. Is there something similar in octane?
Posted: Mon Aug 11, 2014 7:46 am
by juanjgon
geo_n wrote:If you guys are working with linear workflow in octane, how do you degamma textures?
You have a gamma setting in the texture image node.
Posted: Mon Aug 11, 2014 12:51 pm
Juanjo, jump up 4 posts please and let us know if this is possible.. or what alexos suggested. ;)
Posted: Mon Aug 11, 2014 12:55 pm
by juanjgon
FrankPooleFloating wrote:Juanjo, jump up 4 posts please and let us know if this is possible.. or what alexos suggested. ;)
Let me think about it, I am not sure if it is possible with the current LW SDK.
Posted: Mon Aug 11, 2014 2:14 pm
Hmmm. Well, a windows alert would be perfect, as alexos mentioned. You seem to be able to use alerts, since we do get them for things like "ERROR: Octane plugin is already enabled"... You don't even need to test for current color space settings programmatically. Just make alert pop up every time we switch to Octane. Please make something happen with this J. Losing an hour or more to CS woes is effing brutal. Like watching a horrible flick and wanting that chunk of your life back. ;)
