Page 14 of 15
Re: Cinema 4D version 4.01.1-R2 (stable) 13.12.2018
Posted: Fri Jan 04, 2019 9:08 am
by Ferdinand13
I've come across an issue, where the Object Layer Color and the Shadow Passes don't match.
Here's the combined image I get - see the bright line on the edge of the object?
This is the Object Layer Color Pass on its own (the object color is red and with the green and blue channels set to the red channel it comes out white).
And this is the Shadow Pass.
Now when I use the Object Layer Color Pass to cut out the object from the Shadow Pass, the same line occurs.
Ergo, the two passes don't match, by quite a bit. Is this a bug and how can I fix it? Cheers!
Posted: Fri Jan 04, 2019 9:41 am
by sdanaher
Not sure if already asked but please disable denoising for Mat ID passes - it breaks them.
Posted: Fri Jan 04, 2019 9:43 am
by Ferdinand13
sdanaher wrote:Not sure if already asked but please disable denoising for Mat ID passes - it breaks them.
Hi sdanaher,
I didn't use any denoising in this render. Any idea, why this happened anyway?
Posted: Fri Jan 04, 2019 11:07 am
by sdanaher
Sorry Ferdinand13 - not meant for you, meant for Ahmet as a global comment.
Posted: Sun Jan 06, 2019 10:46 am
by thanulee
Hi, splines do not render in PV while i see em in LV when inside a cloner.
Is that a limitation or did i do something wrong?
file:
https://www.dropbox.com/s/02k9ms8a9l0hw ... s.c4d?dl=0
ty
Posted: Mon Jan 07, 2019 2:34 pm
by Ferdinand13
Hey, I hope nobody minds me bumping this again, but I haven't heard any reply and I'm desperate to solve this. My entire workflow for this project is based on the shadow pass matching all the other passes, that I need to get this fix. Anybody got an idea what could cause this discrepancy between the shadow pass and the object layer color pass? Ahmet maybe? Thanks for letting me know!
Ferdinand13 wrote:I've come across an issue, where the Object Layer Color and the Shadow Passes don't match.
Posted: Tue Jan 08, 2019 3:20 pm
by bepeg4d
sbstnc wrote:bepeg4d wrote:Hi sbstnc,
please, go to System Preferences/CUDA and share a screenshot of the panel, thanks.
ciao Beppe
https://www.dropbox.com/s/b6i6egvgt1yb2 ... 8.jpg?dl=0
From my understanding when I updated to 4.0 (various R releases), while I had to update CUDA and drivers on PC, Mac was fine to use existing.
I may have missed some vital information in a post? I tend not to update if everything is stable. As I said in previous post, changing from 4.0 to 4.01 (with no other system change) sees a huge slowdown in performance, while working in C4D with LV on and when rendering to PV.
and Happy New Year!
my suggestion is to install the latest Apple Security Update for Sierra, and update the drivers to 378.05.05.25f12:
ciao Beppe
Posted: Sat Jan 19, 2019 3:21 pm
by thanulee
Hello. Relink textures doesnt work in R20. Could u check please? thanks
Posted: Sat Jan 19, 2019 7:09 pm
by aoktar
thanulee wrote:Hello. Relink textures doesnt work in R20. Could u check please? thanks
Yes I did in past. Don't know why, I haven't change anythings between R19 and R20.
Posted: Thu Jan 24, 2019 4:11 am
by sbstnc
Will 4.01.1R2 C4D plugin work with the new 4.02 Standalone?
Interested in some of the bug fixes in that release.
S
