Page 14 of 26
Re: Version 3.00 - R1.1 (25.05.2016) - Stable version
Posted: Wed May 25, 2016 6:50 pm
by jingles
Do i need to install CUDA Toolkit to get it to work?
This wasn't the case before so is a surprise if so.
I've got NVidia 368.22 drivers, but Cinema won't let the viewport work.
Posted: Wed May 25, 2016 8:00 pm
by momade
Hello aoktar.
Thank you for your V3 plugin.
I am completely new to V3 and volumetrics.
This question might have been asked already, but is it right, that i can only fill primitives with fog? once I make i.e. my shpere editable the fog is gone...
Kepp it up!
Mo
Posted: Wed May 25, 2016 9:21 pm
by momade
momade wrote:Hello aoktar.
Kepp it up!
Mo
Sorry. Even only shperes work. any reason for that?
Posted: Wed May 25, 2016 9:53 pm
by aoktar
Simple and faster. It's experimental atm. Not easy and fast to convert meshes to voxels. It's quite bit job when you think workload of Octane side.
Also i don't advice to use in any work atm. Because i can change behaviour/workflow and parameters for that.
Posted: Wed May 25, 2016 9:58 pm
by momade
all right. got it. thank you for the quick answer.
if we could fill ANY volume with smoke in the future, that would be great!
Posted: Wed May 25, 2016 10:53 pm
by DinoMuhic
Can't make the TurbulenceFD examples provided here to work.
I cached the sims but octane wont show any volumetrics.
I am using the learning edition of TFD, could this be the reason?
Its on Win 10.
Posted: Wed May 25, 2016 11:06 pm
by aoktar
DinoMuhic wrote:Can't make the TurbulenceFD examples provided here to work.
Its on Win 10.
I need to revise some scenes. Things has been changed since revisions.
But make a quick test with a new file. Just use density. Put an object tag. It will make some proper settings for you. So you can get a closer look after that. Of course you need to tweak parameters further.
Posted: Wed May 25, 2016 11:29 pm
by eightvfx
Hello !
> login with 3 beta 2 works fine with stand alone and plugin,
but > for 3 release >> impossible to login with same login information.
thanks.
Posted: Wed May 25, 2016 11:32 pm
by aoktar
eightvfx wrote:Hello !
thanks.
Open V2/V3 standalone. Make sign-out from account section. try again.
Posted: Thu May 26, 2016 12:02 am
by eightvfx
I uninstalled v3 release,
> did install v3 beta2 and started the standalone to sign out from it.
> uninstalled it.
reboot.
install again v3 release.
and still this error message.
