Page 14 of 31
Re: Beta 0.72 (SDK 1.20)
Posted: Sun Aug 04, 2013 9:00 pm
by EdCast
Does the field of view work with the plugin?
It doesn't seem to do anything for me...
Works in Octane standalone, but not in C4D.
Posted: Sun Aug 04, 2013 10:00 pm
by aoktar
EdCast wrote:Does the field of view work with the plugin?
if you tell of fov on octane cameratag, does not. It uses camera fov.
Posted: Sun Aug 04, 2013 11:10 pm
by dinf
don't know if this belongs to the Cinema Plugin or Octane itself: since I have a Palit GTX 780 Jetstream, the LiveViewer sometimes stopps rendering directly after export with first sampling, so I see a very grainy picture, thats all. In the info line one can read then
Devices Dev0:35,
Mostly, from seconds to a minute later, rendering goes on then.
Do you have any idea what this is?
Posted: Sun Aug 04, 2013 11:48 pm
by aoktar
dinf wrote:Hi,
Devices Dev0:35,
this shows need to select gpu priority option. Otherwise gpu rendering don't allow viewport refresh and live viewer refresh.
Posted: Mon Aug 05, 2013 7:25 am
by NVN
@dinf
the same by me!
yeear im not alone :-)
aoktar, in your last version it works perfect, only since your last update...
i dont believe that is a priority problem....
Posted: Mon Aug 05, 2013 8:22 am
by dinf
aoktar I see "use Pri." was unchecked, Render priority is set to low, and will have a sharper look at the info line from now on. I was wondering because this info and renderstop wasn't there all the time I worked with the slow 560 Ti, but as you know I changed the plugin two times between.
The settings should not be touched by that, right?
Posted: Mon Aug 05, 2013 12:57 pm
by aoktar
NVN wrote:@dinf
the same by me!
can you test to drag some windows while rendering? can it be smoothly moved?
Posted: Mon Aug 05, 2013 1:04 pm
by NVN
yes...all move smooth.
at the same time i can watch a movie too
My GTX 470 is only for my System.....
how i told, its not every time....but sometime
Posted: Mon Aug 05, 2013 2:05 pm
by aoktar
NVN wrote:yes...all move smooth.
can you try to disable Hw opengl in Cinema4D for testing
Posted: Mon Aug 05, 2013 4:29 pm
by dinf
aoktar wrote:can you test to drag some windows while rendering? can it be smoothly moved?
With "Use pri." activated all smooth and so far no "devices dev:0" info, without all windows moving in steps.
