Page 115 of 172
Posted: Wed Jul 06, 2022 6:58 am
by bepeg4d
OctaRamen wrote:Hello, I am using Octane Blender in M1 with Monterrey, and I am having issues that I see also other are posting in this forum.
- I can not select or move objects on the viewfinder and mouse, I can just select from the layer/tab and move with shortcuts.
- The menus on the windows are overlapped, sometimes is not possible to change fro example from viewport to timeline or so.
I would appreciate if someone can advice me, cheers!
from what you have written, it seems that plugin is not correctly installed.
Please write to help at otoy dot com, asking for Beppe, thanks.
ciao,
Beppe
Posted: Sat Jul 23, 2022 9:29 pm
by cosmic3d
ok,
so, I'm assuming it's fruitless trying to get anything to work on my build
Compute error 2097152:825:
compute device 0: Linking 00696900aaaadec4 shader failed
device 0: failed to initialize render thread 0x7fd946711ab0
OS:
Monterey 12.4 (21F79)
GPU:
AMD Radeon RX 580 4 GB
Processor:
3.6 GHz 10-Core Intel Core i9
Memory:
64 GB 3200 MHz DDR4
I'm pretty sure that it's not going to work at this point...
Is there anything simple I'm missing?
I'm guessing that my card isn't compatible at all.
I'm using: C4D_OctaneX_Prime_PR14.zip
with R25 C4D
Would that be correct?
Is there anything I should try? Or should I give up?
thanks
Posted: Mon Jul 25, 2022 8:29 am
by bepeg4d
cosmic3d wrote:ok,
OS:
GPU:
Processor:
Memory:
64 GB 3200 MHz DDR4
with R25 C4D
thanks
Sorry, unfortunately AMD Radeon Pro 580 is a Polaris GPU, but AMD Polaris and Intel GPUs are not supported anymore in new OctaneX PR12/13/14 for macOS 12 Monterey - there were some Apple Metal driver related issues.
Is it possible for you to downgrade or install Mac Os 11.6.7 on another partition, or an external sdd/hdd?
https://www.macworld.co.uk/how-to/mac-s ... e-3659666/
In this way you could continue to work with PR11 under Big Sur, but with C4D S24, since C4D R25/26 are not supported in Big Sur.
ciao,
Beppe
Posted: Tue Jul 26, 2022 2:06 pm
by cosmic3d
thanks Beppe, I will see what I can do
Posted: Mon Aug 01, 2022 6:54 am
by shtl_1
Hello
This morning I get an error message from apple/OS X Monterey, 12.4, blocking Octane (and Forester Plugin too)
Updated OS to 12.5 but problem persist.
It was working Friday.
Usually when apple block a software I can go to security to allow the software, but this time I didn't find anything since it's not a dot app but a library.
Any clue on what to do ?
Attaching a screengrab, in French, it says something like:
"impossible to open "liboctane.dylib" because apple cannot verify blah blah, this software must be updated. Contact the developer to know more."
Thank you
PS:
Mac studio M1, c4d r25 roseta mode, octane PR14
Posted: Mon Aug 01, 2022 7:03 am
by shtl_1
OK solved, you can delete the messages. It is possible to unlock the dylib if manual opening them in finder.
Posted: Fri Aug 05, 2022 10:02 am
by bepeg4d
New OctaneRender® for Cinema4D version 2022.1-XB3 (Experimental) 05.08.2022:
- Added first 2022.1 support for native M1 Macs
- Scatter object: New WIP distribution mode POISSON and fix for distribution issues with old Surface mode.
- Several fixes
viewtopic.php?f=85&t=80247
Remember to disable the
Open using Rosetta option in the Info of the Cinema 4D.app:
You also need to allow the c4doctane plugin and library in System Preferences/Security and Privacy panel, and restart C4D a couple of times.
Finally, you need to go to c4doctane Setting/Nodes, and disable the
New style option, or material preview doesn't work in node editor:
It is a Prime free version, so every Mac Octane users with Apple Silicon GPU can install it.
Happy Mac GPU rendering!
ciao,
Beppe
Posted: Tue Aug 09, 2022 10:26 am
by pcb
I just tested the new version but had a crash after a few minutes. I have attached a link to a screenshot and a bug report.
Bug rapport:
https://www.dropbox.com/s/0r37qesznqu8n ... t.zip?dl=0
Best,
Peter Boldsen
Posted: Thu Aug 11, 2022 8:12 am
by bepeg4d
New updated 2022.1-XB3-R2 version with some fixes:
https://render.otoy.com/customerdownloa ... R2_OSX.zip
@pcb: please open the scene, then go to c4doctane Settings/Log Output tab, and enable all the Log option checkboxes.
Then, load the scene in Live View, then in Picture Viewer, or until crash, then reopen c4d, navigate to c4doctane Settings/Log Output tab, press the
Generate log report button, and share the resulting
octanelog_report.zip file, thanks.
ciao,
Beppe
Posted: Sun Aug 14, 2022 9:48 am
by olavalvons
Hey, thanks for the Update!
Are there plans for making the Photon Tracer part of octane x?
Thanks in advance,
Mitch
