Page 12 of 15
Re: Cinema 4D version 4.01.1-R2 (stable) 13.12.2018
Posted: Sun Dec 23, 2018 11:23 am
by aoktar
thanulee wrote:Yes my friend, first time the stable version. I had tested the previous RCs as well, and i had similar issues, mostly cuda errors.
What other plugins u suspect? I use TFD/XP/Realflow/Forester as main plugins! thanks
I don't widh to name it, but there's a possibility! Do you have a render failure too before crash? Please PM me to follow up the issue if you wish
Posted: Mon Dec 24, 2018 12:31 am
by thanulee
All is better now with R20, no crashes so far on few small scenes! Its faster overall! One question, is this possible to have random color on this setup?
link:
https://www.dropbox.com/s/olaf1xckdgqop ... e.c4d?dl=0
Posted: Mon Dec 24, 2018 5:21 pm
by thanulee
Hi, when i convert a diffuse octane mat with SSS to sub, it loses the transmission color.
Is that behavior proper? ty
Posted: Mon Dec 24, 2018 5:35 pm
by aoktar
thanulee wrote:Hi, when i convert a diffuse octane mat with SSS to sub, it loses the transmission color.
Probably yes, please share material to check
Posted: Mon Dec 24, 2018 6:30 pm
by thanulee
Here it is:
https://www.dropbox.com/s/z1hzkiicr7bz9 ... .webm?dl=0
edit: if ihave map on transmission doesnt keep it as well.
Posted: Mon Dec 24, 2018 6:39 pm
by aoktar
I see, will fix it. Thanks for reporting it!
Posted: Mon Dec 24, 2018 6:45 pm
by thanulee
Thank u! And Merry xmas !
Posted: Wed Dec 26, 2018 6:32 pm
by Domenicozzo
Hi Ahmet and Merry Christmas to you and everyone.
Is there a way to render out denoised volumes in one take? I mean, kinda like we get thicking ON "Use Denoised Beauty Pass" in the Main Settings?
Would it be hard to include also the volumes adding a "Use Denoised Volume Pass" for future releases?
Great work with Octane 4 btw, just upgraded from 3 and it works great.
Have a great one,
Domenico
Posted: Wed Dec 26, 2018 10:13 pm
by divasoft
Hi Ahmet. Can you fix this bug? Generator nodes does not show texture what generated.
I have to guess every time what happens at the end. See how it works in substance designer. You need to make it work the same way.
Posted: Wed Dec 26, 2018 10:18 pm
by aoktar
divasoft wrote:Hi Ahmet. Can you fix this bug? Generator nodes do not show texture what generated.
Hi! Unconnected nodes will not get previews. See picture. It's a limitation.
